Results 1 to 6 of 6
Thread: Adding a Wing to the Saw
    I finally got off my duff and started the process of moving my TS and adding a wing. I gained an extra 10" of fence capacity through shifting the Bies tube but never added the wing to support it.
    Here's the existing table top real estate; saw, three wings and router table. You can see the extra front rail capacity in the left of the pic:
    I forgot how many parts there were to this thing:
    I forgot how heavy these were too . . . and I'm adding another?
    Boy this little guy really looks little once he's all on his lonesome.
    I did a cleanup and a full alignment and posted that in this thread: http://www.familywoodworking.org/for...ad.php?t=14226
    It's lunchtime, I'll be back.
    I had to drill holes in what used to be the last wing on the right.
    With that done I used a couple roller stand to help me hold the wing up whilst inserting the bolts. Using this method got the original two wings on quick. Two more to go.
ID:	32194 Click image for larger version.
    Of course no project is complete without having to run to the store for a couple parts that will cost less than the gas to get there and back .
    17,470
    hey glen have yu thought about the weight hanging out there on those new wings. now your relying on bolts and the irons integrrity to hold up.. just thinkun out loud,, one is one thing but two is another...
    Thanks for watchin' out Larry. I should have shot the first pic from the other side. There is a leg on the right that holds all my accessories on a slide out panel.
    It will return to that position as it is at the end of the front and rear rails. I will build out more floor standing support beyond it for the final wing and overarm DC mast support. The important thing here is to make sure everything sits level and well aligned without being forced. Once it is standing happy, bolt 'er down. This is definitely a "If in Doubt, Build it Stout!" situation.
    17,470
    gotta look out fer yu city folk ,,sometimes ya go to fast fer your own good
    Sorry, I wandered off and forgot to post a completed shot. I gained 12" of table top and have 40" of rip capacity now. Thanks to things I've learned on the forum I now have the saw better aligned than ever before to boot. Thanks all.
  1. Wing nuts source needed.
    Last Post: 11-08-2014, 04:24 AM
  2. TS Wing Router Ver 2.0....?
    By Stuart Ablett in forum Jigs and Fixtures
    Last Post: 10-28-2013, 05:17 PM
  3. Hinged TS Extension Wing
    By Al Launier in forum General Woodworking Q&A
    Last Post: 02-12-2013, 08:16 PM
  4. Flying with one wing
    Last Post: 03-26-2010, 05:48 PM
  5. Router wing extension in TS
    By Ned Bulken in forum Designs, Plans and Sketches
    Last Post: 08-27-2009, 10:36 PM
