Results 1 to 10 of 14
Thread: How long does it take to turn turnable?
    May 2009
    Lafayette, Indiana
    2,380
    I want to try my hand at something bigger than a Yo-Yo. I recently cut down a apple tree in my back yard. I kept the wood for my fireplace but now I want to turn some of it so I would like to know about how long it would take for this wood to dry out to a place where I could turn it. After finding this site recently I'm now inspired to try to make something larger than what I have done in the past. If I keep some of the wood dry by putting it in my garage....how long? A year...two??? Do I just leave it with the bark on it? I have it cut up into about 10-15 inch long peices that are about 6-12 inches across.
    Tom
    17,470
    I AM NOT A TURNER,,,, but here there are many that turn there projects green... and use the dna method of drying..
    May 2009
    Lafayette, Indiana
    2,380
    dna?????? I'm new so could you please explain. Thanks.
    Tom
    May 2009
    Lafayette, Indiana
    2,380
    I did a quick search (sorry, should have done it before replying) and found several good threads about DNA drying. Intresting reading. I've got a lot to learn.
    Tom
    Tellico Plains, Tennessee
    4,351
    Tom,
    Look into microwave drying as well... takes less time than the DNA..
    With DNA you submerge the wood and soak for a day or two, then let it dry for a couple of weeks to a month... depends on the wood.
    With the microwave, you can dry pretty quickly... run it for a couple of minutes, let it cool, re run for a couple of minutes, let cool, etc... you'll need to have a means to weigh or a moisture meter to check moisture content... might take a couple of hours or so this way. I start with the defrost cycle for two or three cycles, then up to the simmer/stew cycle for a few... don't usually do more power than the simmer... you can burn the wood if you get too hot and microwaved wood that smokes smells as bad as burnt microwave popcorn.. (DAMHIKT)
    I use both methods, depending on what I need to get done.
    Chuck
    Tellico Plains, TN
    May 2009
    Lafayette, Indiana
    2,380
    Tom,
    A microwave...never thought of that. Surly you don't use the "kitchen" microwave. Sounds like it would be fast but I'm not to sure what the wife would think.......although I do get home from work before she does.....lol. I might have to look into finding an old unused unit to keep out in the garage.
    Thanks for the information.
    Tom
    Goodland, Kansas
    4,834
    I use the DNA method of drying. I have found fruit wood in a microwave cracks on me. Maybe I am doing something wrong but I think you can dry to quick. I have had better luck with other woods. Yes I would find a old one at a garage sale. Momma doesn't like me using her's.
    Bernie W.
    30,008
    Dan, I'll echo the other suggestions to turn the wood green, then dry the rough-turned piece. If you try to let a piece of apple wood dry on its own (or most any other type of wood), it's almost guaranteed to crack. I use the DNA method for nearly every piece I do, and have had good success with it.
    IMPORTANT ANNOUNCEMENT TO THE COLLECTIVE:
    It should be noted that on this day, Larry gave actual (and correct) turning advice. Phase I of the Abysseration appears to be well under way. Continue with Phase I actions and be on standby for Phase II activity upon further notice.
    Resistance is futile.
    That is all.
    Oct 2007
    Schenectady, NY
    912
    Roger that Vaughn-standing by.
    We'll get him yet!
    Don Orr
    Woodturners make the World go ROUND
    May 2009
    Lafayette, Indiana
    2,380
    You guys are brutal...lol
  1. Replies: 1
    Last Post: 09-19-2014, 04:50 PM
  2. Replies: 24
    Last Post: 07-04-2014, 02:04 AM
  3. Is a root ball turnable?
    By Tom Baugues in forum General Woodturning Q&A
    Last Post: 10-13-2010, 11:28 PM
  4. How To Turn a Box
    By George Watkins in forum Tips and Tutorials
    Last Post: 05-06-2009, 05:13 PM
  5. Purpleheart: How long, O! lord, How Long?
    Last Post: 02-28-2007, 03:38 PM
