Results 1 to 10 of 10
Thread: Napkin Rings
    33.8736N, 117.7627W
    435
    Napkin Rings
    Got a request to do a set of napkin rings...does anybody know offhand if there's a "standard" size for the hole?
    Where are we going? And what am I doing in this handbasket?
    Big enought to stuff a napkin in ...
    33.8736N, 117.7627W
    435
    Well, the $2 per 5000 paper napkins from Sam's Club roll up to about 1/4" diameter, so I guess I can use that as a lower limit...
    Here you go Lee, I googled napkin rings and found this
    http://www.madnik.com/napkin-rings.html
    Doesn't apear to be a standard size.
    33.8736N, 117.7627W
    435
    Assuming those are inside diameters they list...
    Starting to look like 1-1/4" to 1-5/8" is the answer, with wider ones being bigger (which sort of makes sense, I guess).
    Thanks!
    Northville, MI
    507
    Recalling from the nicer restaurants that I've been in, the holders usually have a 1" or so inside diameter. Cloth napkins need quite a bit of space. I would measure one from our house but we don't have any since we just use our sleeves.
    Jim
    30,136
    Quote Originally Posted by Jim Young View Post
    ...I would measure one from our house but we don't have any since we just use our sleeves.
    Here in Southern California, we're more couth...we use the tablecloth. Plus, it's usually too hot for sleeves.
    Austin, Texas
    1,454
    The ones I make are about 1 3/4" ID, but that is a little larger than ones we purchased decades ago.
    It started with a leftover segmented "circle" from a bowl, which became a bracelet, but it was thick enough that the "waste" inside the bracelet became a napkin ring. Watch out... if you get started on bracelets and napkin rings, the demand may keep you from getting back to bowls.
    Charlie Plesums, Austin Texas
    33.8736N, 117.7627W
    435
    Quote Originally Posted by Charlie Plesums View Post
    Heh. This whole thing started because my mom saw this and thought it was a napkin ring...
    ... until she realized it had a bottom.
    Houston, TX
    363
    Well Lee, at least your Mom uses napkins.
  1. Exquisite wooden rings
    Last Post: 04-29-2016, 03:12 PM
  2. Rings.
    By Kevin Vernon in forum Flatwork Project Showcase
    Last Post: 09-10-2014, 01:28 PM
  3. More Key Rings
    Last Post: 02-07-2014, 06:46 AM
  4. Rings
    By Rick Prosser in forum Lathe Project Showcase
    Last Post: 08-25-2011, 05:15 PM
  5. PRL, etc. Aluminum Twist Rings - Going, going . . .
    Last Post: 05-12-2010, 07:32 PM
