Results 1 to 4 of 4
Thread: Enough on ZCI's Yet?
    With the recent tune up of my saw I invalidated all my ZCI's. Making these after you already have some is a snap. Trace out a few (don't forget some spares) and rough cut to size and shape.
    You can pass on the double stick tape and just drive screws in where the adjuster screws were in an old ZCI. The hole the screw makes in the new blank will get eliminated when the adjuster hole is drilled.
    A top/bottom bearing pattern bit is great for this because you can route part of the pattern, adjust the bit height, flip your material/pattern and always be routing downhill; no chatter or blowout.
ID:	32265 Click image for larger version.
    I leave a little beaver tail at the back that I shape vs. using a pin but I've done both. My current batch will have a little bigger tail.
    Getting the insert into the opening to make the initial cut is something I have seen some folks struggle with. Using a smaller blade or the outside of your dado set will work but, I just route a stopped groove. Since I already know exactly how much space I need based on the old ZCI its faster this way for me.
    Put the insert in the throat, adjust for level, clamp it down (or lock your fence over it), raise the blade to make the initial cut, drill the holes for the MJ Splitter and I'm all set.
    I do one for every blade I have and a couple extras for dados or angles. When you do them in a batch they don't take long at all.
    17,472
    well done and thanks for sharun if i understand you correctly glenn your counter sinking a screw in the last pick that you use for leveling purposes???
    12,258
    Thanks Glenn. I always pick up a tip or two from these posts. I like the beaver tail.
    You solved a long time agravation with that slot idea to overcome the initial blade height.
    Thanks for posting and sharing your ideas.
    I apologize Larry. I left the whole DP and hole drilling section out of this . . . it was close to my bedtime . I use 1/4-20 by 3/8" long allen set-screws for levelers. They are cheap and readily available at the BORG and they thread easily into the 13/64 holes I drill at each of the four positions.
    The other holes you see at the rear are for the MJ Splitter. The other holes at the front are a 3/4" through hole for grabbing the insert when changing and a stepped hole, second from the front left, that accepts the retaining screw that my saw uses.
