Results 1 to 10 of 12
Thread: cherry coffee table
    Dec 2008
    falcon heights, minnesota
    5,609
    cherry coffee table
    now that i have gotten my sis in law's frames out of the way, i can continue on with more important projects.
    this is the coffee table that was inspired by a greene & greene lamp shade.
    Attached Thumbnails Attached Thumbnails cherry coffee table parts.JPG   cherry coffee table.jpg
    benedictione omnes bene
    www.burroviejowoodworking.com
    17,472
    hey dan,, either you eat the same thing each day or you are doing two things at once???? and do you do most of your work in the room you are displaying your wood in? i thought you had a shop also could you do a short tutorial on how you did the bread board ends so that guy over in jersy area could see some of the steps.. hey understands pictures better than words sometimes
    Dec 2008
    5,609
    the first is an older pic (u din notis larry?)
    i'll try to keep up with the pics as i build this one.
    Sep 2007
    Plainwell, Michigan
    4,857
    Thats one fancy glue-up room Dan mine only has concrete floors Table is lookin good
    Dec 2008
    5,609
    oh, if i were to be doing the glue up in the living room, i'm certain the wife would have something to say about it.
    all i did, was to lay out the parts where they would be going, and to mark the tenons, and arcs. more fun tomorrow.
    new york city burbs
    10,188
    [QUOTE=larry merlau;161460]also could you do a short tutorial on how you did the bread board ends so that guy over in jersy area could see some of the steps.. hey understands pictures better than words sometimes:r
    one more state to the right larry.
    Bellingham
    2,449
    Ouch Larry, having lived and worked in New Jersey for a couple years I know what New Yorkers think of Jersey.
    "Do you know why New Yorkers are always so depressed?
    Because the light at the end of the tunnel is New Jersey."
    17,472
    hey i will get me goegrapghy right some day that might be why i drive so far to get nowhere
    Sep 2007
    Central (upstate) NY
    1,457
    Ok, I'm going to ask the stupid question. Why doesn't a breadboard table fail due to wood movement?
    Shouldn't it be expected to fail because the ends are crossgrained to the rest of the table, causing the rest of the table to expand and contract more than the ends will?
    Thanks!
    The ends do not gat glued on but are typicaly attached with 3 dowels from underneath. One dowel in the center and the 2 outer dowels you drill the hole , remove the breadboard end, elongate the hole in the top. then reattach the breadboard end and insert the dowels. you also make the tenon about 1/2" shorter in width than the mortise to allow for expansion
  1. small cherry/spalted maple blanket chest/coffee table
    Last Post: 12-30-2014, 04:59 PM
  2. Coffee table
    By Dave Black in forum Flatwork Project Showcase
    Last Post: 12-30-2011, 04:26 AM
  3. Coffee Table
    By Dawson Mossman in forum Flatwork Project Showcase
    Last Post: 09-29-2009, 03:36 PM
  4. Coffee table top
    By Dawson Mossman in forum General Woodworking Q&A
    Last Post: 09-09-2009, 05:23 AM
  5. coffee table in cherry finished
    Last Post: 05-29-2009, 04:20 AM
