Results 1 to 10 of 26
Thread: Green Maple HF
    Oct 2007
    Harvey, Michigan
    687
    Green Maple HF
    Every once in a while I like to experiment with color. This maple HF has plenty going for it already with voids, bark inclusions and curl, but I thought a little color would be interesting.
    Maple, 5 ¼” diameter x 4 ½” high, sanded to 320 grit, colored with RIT ‘Kelly Green’ dye mixed with DNA, several coats of Minwax Wipe-On Gloss Poly. I will wait for a week or so for the finish to cure a little more and then buff.
Name:	Green Maple HF v1.JPG
ID:	32466 Click image for larger version.
Name:	Green Maple HF v2.JPG
ID:	32467 Click image for larger version.
Name:	Green Maple HF v3.JPG
ID:	32468 Click image for larger version.
Name:	Green Maple HF v4.JPG
ID:	32469 Click image for larger version.
Name:	Green Maple HF v5.JPG
    As always, your comments, critiques and opinions are welcome!
    Thanks for looking!
    Steve
    Red Deer, Alberta, Canada
    618
    Wow, I like that color! Looks great as it is; hope you'll give us another look after buffing it, Steve.
    Why has common sense
    become so uncommon?
    My Woodwork Site
    Goodland, Kansas
    4,834
    Steve that is beautiful. Well done.
    Bernie W.
    3,132
    wow is right!I must say i really like that color you chose
    Steve
    Great HF (as we'd expect from you), but as much as I like playing with color, this particular green doesn't really send me. I'm sure someone will just HAVE to own it when they see it, though.
    Sep 2008
    Redford, Michigan
    53
    Steve, that's a fine looking Granny Smith. Though seriously, nice job and I LIKE that color.
    Oct 2007
    Harvey, Michigan
    687
    Thanks for the kind words everyone! I do appreciate it!
    Vaughn - I am not much of a 'green' color kind of guy but it is my wife's favorite and she loves it. Enough said... I was hoping for a darker green and may have to play around a little with the color mix. Got another HF on the lathe right now that has a lot of curl and I think it could really pop with the right color added. We'll see.
    Steve
    Quote Originally Posted by Steve Schlumpf View Post
    ...Vaughn - I am not much of a 'green' color kind of guy but it is my wife's favorite and she loves it. Enough said...
    I'm in a similar boat. I could turn a total trainwreck of a form, but if I made it green, LOML would be all over it. I was playing around dying some fairly plain maple confetti lights recently, and went looking through my Transtint stock to see if I had green, and I didn't. I opted for blue, hated it, and sanded it all off. It dawned on me later that I could probaly mix my blue and yellow dyes to get something green.
    Oct 2007
    Harvey, Michigan
    687
    Vaughn - so far the only dyes I have used have been RIT and the only colors I have are red and green. This was my first attempt at green and the darker portions of it look OK to me. It's the lighter - granny smith apple green stuff that I don't like. Part of it was the maple - didn't suck in the color like my experience with white birch! Huh, go figure!
    Anyway, I do like playing with color and may opt to start thinking about a small air brush or something to have a little more control instead of just brushing it on - wiping it off.
    Steve
    Steve, I tried an airbrush, but wasn't able to get as wide of pattern as I wanted. (Probably operator error.) I ended up with one of these with an assortment of tip sizes:
    http://www.spraygunworld.com/product...ray%20Gun.html
    I still have the airbrush (a Paasch) and some day I may actually learn to use it for more detailed work.
    Are you using the pre-mixed Rit dyes or the powered ones? I've used the black pre-mixed stuff and it worked OK, but it tended to raise the grain. (In hindsight, I should have wet the wood after sanding it, then re-sanded before dying it.) One of the things I like about the Transtint dye is that you can use DNA as a carrier, so it doesn't raise the grain nearly as much.
  1. Green and Green square plugs
    By Charles Hans in forum General Woodworking Q&A
    Last Post: 02-01-2013, 12:40 AM
  2. Green house
    Last Post: 09-14-2011, 09:33 PM
  3. Southwest Style Green Maple HF
    Last Post: 05-19-2009, 11:35 PM
  4. Green wood
    By curtis tolbert in forum General Woodturning Q&A
    Last Post: 06-14-2008, 06:26 PM
  5. Going Green??
    By Denise Walsh in forum Carpentry and Construction
    Last Post: 05-04-2008, 01:37 AM
