Results 1 to 7 of 7
Thread: busy day today!! part one
    Dec 2008
    falcon heights, minnesota
    5,610
    yours truly was truly a busy monkey today
    i managed to get all of the parts (except for the 4 posts) for the grandfather clock cut, refined the frame for the drop in cushion for the foot stool, and did the refining cuts, cut all mortises and tenons, and got the breadboard ends set up for the coffee table. the way i'm doing the breadboard ends is this, i cut a long mortise in the breadboard end, then cut tenons on the ends of the parts for the top, then cut in the outer corners on the tenons to have about 1/4" play on the ends. i then found (not that they were lost mind you ) centers of all the top board ends, and cut a shallow mortise, then drilled a hole for the screws, which will be covered up by a nicely contrasting plug. the outer boards fit nicely, but for some reason, the inner ones will need some persuading.
    Attached Thumbnails Attached Thumbnails start of day.JPG   grandfather clock boards.JPG   grandfather clock parts cut.JPG   making long mortise in breadboard end.JPG   one end done.JPG
    both ends done.JPG   getting tenons ready on the top.JPG   cutting tenons.JPG   checking the fit.JPG   ends mortised for screws and plugs.JPG
    benedictione omnes bene
    www.burroviejowoodworking.com
    Dec 2008
    5,610
    busy day!! part 2
    the rest of the pics!!
    Attached Thumbnails Attached Thumbnails coffee table parts.JPG   tenons and arcs cut.JPG   squaring up the legs.JPG   legs sqared, mortised, and chamfered.JPG
    The way your movin along Dan it looks like you might have a plan. Are you competing with Allen to see who can complete a project the fastest.
    new york city burbs
    10,188
    you cut the tenons on the ends of each board individually.
    are you going to glue up the boards of the tabletop?
    You're making better progress than I typically do.
    I did notice something in this pic:
    http://familywoodworking.org/forums/...6&d=1242609284
    Using the miter gauge and the fence like that is a recipe for a nasty kickback. All it takes is for the board to get a little crooked between the fence and the blade, and it'll be shot back at you in a heartbeat.
    The solution is to use a stop block attached to your fence. You can still use the miter gauge, and the stop block lets you reference off the block and get four legs the same length, but you avoid having a crosscut board between the fence and the blade.
    Here's a quick sketch:
Name:	Stop Block for Crosscutting.jpg
    Dec 2008
    5,610
    Quote Originally Posted by Alan Bienlein View Post
    nah, i'm not competing with allen, i just like to keep things moving along. it is a bit unusual for me to have more than one project going at the same time. i just have to make the most of when we have nice weather, that's the way it goes when you're working in the biggest shop in the world.
    that i did allen, and if i weren't so dog tired and running out of daylight when i was done (started at 10 this morning, and finished up around 6:30 tonight), i would have cut the biscuit slots and the top would be sitting in clamps. but, the 2 center boards have to have thier tenons finessed a little, and i have to clean up the sides of the mortises. i still haven't decided on what will be the plug material yet. i may raid the goody box that don sent, perhaps some curly maple...
    thanks vaughn! i try to make hay while the sun shines. i see your point, and i think i will do that from now on. it may have been dumb luck all this time, but i've yet to have any kickback like that when i do that, but careful is the best way to go. no fun looking for trouble, especially when it finds you.
    Quote Originally Posted by Dan Noren View Post
    ...thanks vaughn! i try to make hay while the sun shines. i see your point, and i think i will do that from now on. it may have been dumb luck all this time, but i've yet to have any kickback like that when i do that, but careful is the best way to go. no fun looking for trouble, especially when it finds you.
    The block on the fence is a little "jig" that takes only a few seconds to add, and the payoff is well worth it. (Fortunately, I was standing out of the line of fire when I learned this lesson years ago. It was like shooting a 2x4 out of a cannon.) I have a 3" x 6" or so piece of UHMW plastic that's exactly 1" thick that I keep by my tablesaw. (Wood works fine, too.) Since it's exactly 1" thick, I can still use the scale on my fence and just add an inch to whatever measurement I needed.
  1. Busy day today
    By Terry Quiram in forum Lathe Project Showcase
    Last Post: 01-07-2016, 08:13 PM
  2. been busy with tests yesterday and today...
    By Dan Noren in forum Computer-Aided Equipment Project Showcase
    Last Post: 07-27-2015, 04:30 AM
  3. Busy day today!
    By Mack Cameron in forum Off Topic Discussion
    Last Post: 01-31-2013, 12:19 PM
  4. another busy day today....
    Last Post: 06-01-2011, 07:05 AM
  5. busy day today
    Last Post: 08-23-2009, 01:25 AM
