Results 1 to 4 of 4
Thread: oil for vacuum pump
    11,831
    oil for vacuum pump
    My Gast vacuum pump has a glass reservoir on the side for oil. The level marker shows the oil to be a little bit low. What kind of oil is used for a pump like this?
    Villa Park, CA
    1,407
    It's called vacuum pump oil. If you go to an air conditioning supply house they'll have it. When you store it, make sure you keep it capped tightly. You don't want moisture to get into the oil - if it does, the pump will not pull as good a vacuum. That's usually the reason you change it in the pump.
    The reason A/C places carry this is because when you break into a freon line (meaning cut the line for some reason, such as installing a new condenser unit), you have to evacuate the line before putting new freon in.
    Mike
    Ancora imparo
    Southeast Pa
    2,019
    Frank
    Try this link
    http://www.mcmaster.com/#catalog/115/2137/=1xdait
    If that doesn't work just go to McMaster Carr and type Vacuum Oil in the search bar or page 2137 at or near the bottom of the page.
    Garry
    11,831
    I wrote Gast tech support. The response said to use Gast AD220 oil or a proper subsitute. They said a good sub. is straight 10W detergent motor oil. Straight is prefered to a multi-viscosity oil but something like 10-20 can be used. Do not use synthetics as they gunk up.
    They gave an expanded explanation of subs. If anyone wants, I'll post the entire letter here.
  1. Vacuum pump
    By Darren Wright in forum General Woodworking Q&A
    Last Post: 03-04-2013, 07:41 PM
  2. Vacuum Pump
    By Chip Sutherland in forum Lathe Project Showcase
    Last Post: 03-03-2013, 04:30 PM
  3. vacuum pump on CL
    By ken werner in forum Hot Deals
    Last Post: 11-04-2012, 11:23 PM
  4. Vacuum Pump
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 03-03-2010, 02:16 AM
  5. Vacuum Pump
    Last Post: 02-27-2010, 04:25 PM
