Leo, this Aparto is about the same size, but I'm renovating every room, except the one the bathtub sits in, so it is a larger scale, but I think it will go quicker, as I'm starting this one with my eyes wide open, understanding that I'm going to tear it all out and fix it all. The first one was more of a step by step up tick in the amount of work that needed to be done.
We have been working, and working hard, I'm wiped out at the end of each day, Jake is working very hard too, it is a blessing to have him here for this
We have found a number of structural issues, but all of them only require an addition of large chunks of wood to carry the load properly, there is almost no rot in this place, very much unlike the first aparto
We have found one footing that needs to be replaced, the piece of wood, the short stubby post between the footing and the floor beam is cracked and the concrete is crumbling, so we will jack it up, and remove the old footing and pour a new one
The other footings have all checked out fine, so far.
I guess I owe you guys some pictures
Here you can see that the kitchen floor and floor joists are history, only the main supporting beams remain, boy what a mess
I went at the mess with a rake and shovel, as well as down on my hands and knees to sort through the wood, rocks and dirt, I got it cleaned up nicely. I'll add vapour barrier and the moisture absorbing rock stuff when we move along a bit further.
This is one that I'm going to fix, it does not make a lot of sense, the second short beam, the one further away from the camera, it is set up so that the floor joists all have to be adjusted around it. If you look on either end, you can see the footing area where you could just rest a beam, if you had the right sized piece of wood. This piece is a bit thinner than the existing pieces, so I guess
that is why it is done this way..............
This is the toilet area, I have to move the pipe towards the wall to use the new toilet I bought, I also have to buy a new mesh for the vent hole there to keep out the rats
Cont.............
