Stuart Ablett
- Tokyo Japan
We hit the ground running today, early start, got a good 5 hours in on the job, plus some noodling
The demo work is done!
We started making sawdust today!
OK, this is in the kitchen area, we put in a new beam that is 11 cm x 11 cm (4 5/16" square). It goes from the wall between the apartos, to the center beam in this aparto, and picks up some floor joists that badly needed some support in the kitchen above. Jake went upstairs and jumped around on the floor afterwards and declared it all good and solid now.
Next up we put a short beam under the end of the joist that the plumbers cut off to run the toilet drain This also really made the floor upstairs good and solid, a bonus came when Jake noticed that the joist was actually touching the pipe, and it squeaked badly each time you stepped into the toilet, now the floor is solid and there is now squeek
Moving into the living room, there was quite the span here with only fairly spindly floor joists holding things up, when Jake jumped around upstairs, the floor moved a good 3/4" or more up and down, like a suspended floor This extra support got rid of that too.
Lastly, this beam is notched into the upright post, but there was an open notch about an inch below it, so there was really not much at all holding up the end of the beam into the post. This block fixed that.
We have more to fix, and some things left to noodle, but we are going well, and it was a great thing today to start building stuff, instead of tearing stuff down!
