Results 1 to 10 of 20
Thread: What do you do if...
    Oct 2007
    Schenectady, NY
    912
    If the piece you are working on is longer than your lathe can accommodate? Why you line up your mini lathe and weight it down with an anvil. Add in a steady rest to manage some of the whip and there you have it. This is a ramming rod for the cannons on the Onrust and it is over 4 feet long. I had to turn down the shaft diameter to Ύ” x 2” long and add a 1.5” diameter head about 3” long with a taper down to the shaft size. Worked reasonably well. The gun captain was very pleased with the results.
    Don Orr
    Woodturners make the World go ROUND
    Nov 2008
    Tampa & NC
    432
    What would you do if
    Now thats using the ole noggin,as the old sayin goes,where theres a will theres a way an it looks like you had a lotta will.
    Well if it works why not!! Looks like something I would TRY usually ending in failure... -- ingenuity and a mix of practicality..
    Goodland, Kansas
    4,834
    Hey Don looks like it worked. Nice thinking.
    Bernie W.
    30,002
    Yankee engineering at its finest.
    Oct 2008
    1,357
    Great thinking but sure scary looking
    Aloha,
    12,243
    Really neat Don. Well done. Also reminded me to go back and check on the Onrust progress. Thanks.
    Palm Springs, Ca
    1,166
    Good idea...........
    Red Deer, Alberta, Canada
    618
    Great thinking, Don! Necessity is the Mother of Invention, isn't it!!!
    Why has common sense
    become so uncommon?
    My Woodwork Site
    11,825
    I thought of a couple possible solutions before looking at yer picture.
    Nothing I had in mind was nearly as clever as what you did.
    I probably would have abandoned the lathe and used a drawknife then fastened the head on afterwards.
    Cannon? Did you say cannon?
    Pictures are required.
