Ill just add a tiny bit.
You've received good advice.
Keep a roll of wax paper in the shop. For glueups.
Cover your clamps, and cauls so nothing sticks. One cheap 99 cent roll lasted me an entire year, and if you want, you can reuse the wax paper over and over again.
If youre using cauls, which I always do, always lay everything out first, dry run, make sure you have enough small clamps to hold the cauls, and make sure the cauls and clamps have enough room underneath the top to clamp securely.
Better to make sure in advance then realize after you have glue all over the clamp wont fit with the caul underneath.
If youre worried about board alignment, take any scraps you have, but middle piece has to be the exact thickness of the top youre making.
Make a bunch of these, or one long one.I make them about 4 inches long, dont forget to line the inside with a touch of wax paper so the glue leaking out doesnt stick to these end cauls.
It will hold the boards in place and they wont move when you clamp.
I use plywood that Id otherwise toss in the garbage.
