Results 1 to 10 of 11
Thread: Picture frame
    May 2009
    Syracuse, Nebraska
    669
    Picture frame
    Hi all!
    My daughter does stained glass work and asked me to make her a frame with a "tropical look". I came up with this idea while cleaning up some scraps of SYP.
    Each segment of end grain is cut to 4 1/2 degrees on both sides times 40 pieces equals 360 degrees. After numerous flip-flops of each piece to try to create a wave pattern, I glued it together with a big hose clamp. Then I made an edge band of brass and heated it up so I could shrink fit it to the frame.
    The inside dia. is about 17 1/2" and outside 20". The finish is a couple of coats of Watco oil, the end grain really sucks it up, and about 5 coats of blond shellac with 400 grit wet sand between each coat.
    I expect she will try something oval next... just to keep me on my toes.
    Constantine, MI
    7,888
    Wow, I'm amazed that you were able to get that to close with no gaps considering that even 1/8 of a degree off per side would have added up to 10! Did it take a lot of hand fitting and sanding to get it all together?
    www.wrworkshop.com
    May 2009
    Syracuse, Nebraska
    669
    Nope, that was just a lumber yard 2X6 that I cut a chunk out of. Ran it through the jointer to get the angles. After the pattern suited me I clamped it dry and every few days snugged the clamp a little more. Construction lumber runs higher in moisture content and by continuing with the clamping for about 2 weeks I think I coaxed the pieces to fit together. When the time came to glue it up it almost fell into place.
    17,470
    well thats a fine job of coaxin and i think that an oval would be no problem fer ya
    What a very cool idea. I think you captured what she was after.
    Oct 2008
    1,357
    You both did good!! Must be New Jersey waves... here they are blue.
    Your daughter got the orchid and the plumeria blossoms perfect and with nice solder lines.
    Aloha,
    30,008
    Very nice work on both the frame and what's in it.
    All I can say Roger is that is awesome looking.
    Indianapolis area
    1,697
    That is most cool! The grain pattern and fit--wow! I some how think there may be some very similar frames being done around here.
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
    Dec 2008
    falcon heights, minnesota
    5,609
    beautiful work roger!!
    benedictione omnes bene
    www.burroviejowoodworking.com
  1. Picture Frame
    By Dan Mooney in forum Flatwork Project Showcase
    Last Post: 02-05-2015, 06:48 PM
  2. Picture Frame
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 08-27-2014, 12:25 PM
  3. picture frame
    By Alan Bienlein in forum Designs, Plans and Sketches
    Last Post: 12-06-2009, 02:28 PM
  4. Picture Frame
    By Aaron Beaver in forum Flatwork Project Showcase
    Last Post: 12-16-2008, 12:13 AM
  5. Hello, Any picture frame builders out there?
    By Curt Fuller in forum General Woodworking Q&A
    Last Post: 06-29-2007, 12:30 PM
