Results 1 to 7 of 7
Thread: Grinder wheel dressing tools
    12,251
    Hi All
    Can anyone advise me on a decent grinding wheel dressing tool.
    I have a delta 8 inch that came with a small t piece type wheel dresser but when i use it the 80 grit wheel is left with groves. It is not exactly a quality device.
    So I am looking for others that people have used and proven worthwhile. Note I can search the web too but thats not what i am after here.
    Thanks
    17,472
    alex posted i his table thread how he sharpens his chisels and he took and used a t shaped thing and said he liked it ..might be a pic of it there and yu can pm and get the brand name...
    Bellingham
    2,449
    Hi All
    Thanks
    What!? You want responses from people with actual experience? Where is the fun in that?
    12,251
    Bill
    my wheel dressers.....everything from my profile grinder to my plain `ol grinder.
    this is a ball bearing unit designed to flatten the face, it uses a coarse grit stone.
    this is a home made "t" stick made with a diamond segment from a core bit, i use it to rough shape wheel profiles.
    this is a coarse stone i use to clean up profiled wheels.
    30,015
    Rob, I have the 'T' shaped dresser, and I move it from side to side as I lightly apply it to the spinning wheel. That seems to handle the 'groove' problem for me.
    If you're looking for the top end of the scale, Oneway's Wolverine wheel dresser is right up there.
    12,251
    Thank you all for the direction. Larry looked up Alexs thread and sure enough he has the same T type Vaughn mentions and the same one that i have. I think I will give mine a little hammer treatment in the high spot area. Its one that seems to have been made on the cheap and the "diamond" (if I believe that) chips are all sorts of sizes and there are a few that stick right out.
    Thanks for the oneway pointer Vaughn, just not in my budget right now. Thanks Todd as usual you have all the down to earth tips.
  1. Tools, after the Grinder - Then What?
    By Jim C Bradley in forum General Woodturning Q&A
    Last Post: 07-14-2014, 05:37 PM
  2. Which Dry Grinder Wheel
    Last Post: 01-04-2013, 06:04 PM
  3. Dressing the bathroom
    By Reg Mitchell in forum Flatwork Project Showcase
    Last Post: 12-24-2008, 09:52 PM
  4. Grinding Wheel Single Point Dressing Jig
    By Chas Jones in forum Turning Tool Questions and Show & Tell
    Last Post: 03-29-2008, 08:56 AM
