Results 1 to 10 of 13
Thread: stripped screws
    stripped screws
    Guys: I have two torx screws in a plastic base that will not budge. Possibly they are stripped although their location makes it difficult to tell. I don't care about saving the screws but would like to save the base. Any ideas, suggestions? Thanks in advance.
    Dan
    Sep 2007
    Central (upstate) NY
    1,457
    Reverse twist drill bits and be very careful?
    Honolulu, Hawaii
    1,103
    stripped screws
    If there is some of the Torx star left, try a proper sized Torx bit with an impact driver, either the hammer type, or a cordless one.
    Aloha, tony
    Ah,,,to live in Paradise!
    Registered voting member
    Rhode Island
    800
    I use that thing you see on TV that takes out stripped screws I found it at the box stores it works very well.
    Floydada, Tx
    1,941
    epoxy the screw head to the driver. Then pull it out.
    Thanks..............Dan
    East Freeetown, Massachusetts
    3,019
    If you grind the torx wrench end FLAT so it has sharp edges - do not deburr.
    Then push REALLLY hard into the torx screw. You want the srape edges of the wrench grab into the bottom of the torx socket. Hopfully the bottom of the torx pocket is not stripped as bad. Maybe it will grab enough to unscrew.
    I'll try it, Leo.
    Dan
    Indianapolis area
    1,697
    There's an old fix that sometimes works for Allen heads that might work on Torx. Just use a dab of old fashioned valve lapping compound on the driver tip.
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
    Attn: Leo
    First, I would like to thank everyone who offered ideas to solve my problem.
    Second, The first one I tried was from Leo Voisine, and it worked like a charm.
    You are the man Leo.
    I am sure many other suggestions would have worked.....I just didn't get that far.
    Thanks again Leo and everybody.
    Dan
  1. Stripped naked
    Last Post: 07-03-2012, 09:31 PM
  2. screws
    By Chuck Beland in forum General Woodworking Q&A
    Last Post: 12-08-2011, 03:30 AM
  3. How much for screws?
    Last Post: 11-02-2010, 12:21 AM
  4. Screw stripped from cabinet
    By Dustin Cranford in forum General Woodworking Q&A
    Last Post: 01-04-2010, 06:04 PM
  5. Stripped gibs?
    By Al killian in forum New Tools
    Last Post: 05-16-2009, 10:18 PM
