Results 1 to 5 of 5
Thread: Ci1 Cutter Source
    Palm Springs, Ca
    1,169
    Ci1 Cutter Source
    Today i had a chance to test out some cutters for my Ci1 i have.....In short they are the same and work perfectly as the originals in my opinion. I bought a pack of 10 and 1 radius cutter - put them up to eachother and side by side and there is no difference in thickness or anything else i can tell. i roughed out several bowls today using it and it works perfectly fine......on the AAW forum someone else posted the vendors name and add etc - i wanted to wait before expressing my opinion until i tried them....In short im glad i bought them and will continue using them - below is the information if anyone else is interested......
    I finally found 2" radius carbide insert for Ci1 Easy Rougher.
    They are designed specifically for wood cutting.
    Made in US by Dehart Tooling
    http://www.dehartusa.com/DeHartWeb/P...c=SquareKnives
    PO Box 3367
    1433 9th Ave SE
    Hickory, NC 28603
    Official name of these inserts: Square Knives Radius & Pointed - 4 Cutting Edges
    Micro Grain Tungsten Carbide
    Part No 06103-019773-14
    Craig(Ci1 guy) sells 3 types of inserts for Ci1:
    1 Ci1 Square Roughing Cutter
    http://www.easywoodtools.com/images/...sert_sq_lg.jpg
    2 Ci1 R4 Roughing/Finishing Cutter
    http://www.easywoodtools.com/images/...sert_r4_lg.jpg
    3 Ci1 R2 Finishing Cutter
    http://www.easywoodtools.com/images/...sert_r2_lg.jpg
    The last one(I like it the most) till now was nowhere to be found other than at Craig's at $14 a pop.
    Square or 4" radius inserts are available everywhere for about $3.
    I don't know the price of 2" radius insert yet but I am sure it'll be around $3-4 each. You'll probably will have to buy 10 pack though.
    11,834
    Got a "not found" message at those links. Also says the page is being worked on.
    Sure would like to find a reasonably priced source for the round cutters.
    Kaneohe HI.
    70
    Cutters
    Got the same results. I like the Ci1 and Ci0. Don't want to go against the Easy woods products ,but the economy can dictate budgets. Savings is the key at this time!
    Southeast Pa
    2,019
    Then hunt around some.
    No a well laid out site but I found them..
    Or you might try this...
    http://tinyurl.com/lt6w5n
    Garry
    Palm Springs, Ca
    1,169
    Link to DeHart tooling
    https://www.dehartusa.com
    the above web add will get you to the site........they have them and the radius cutters.......prices are very good............Dan
  1. Ci1 Cutter question too.
    By Chuck Ellis in forum Turning Tool Questions and Show & Tell
    Last Post: 05-19-2009, 06:25 AM
  2. Looking for thread cutter attachements
    Last Post: 11-14-2008, 11:11 AM
  3. Stake cutter
    By Randy Wynn in forum Jigs and Fixtures
    Last Post: 04-11-2007, 08:19 PM
  4. Dowel Cutter
    By Mike Gabbay in forum General Woodworking Q&A
    Last Post: 02-08-2007, 01:21 AM
