Page 1 of 12 1234511 ... LastLast
Results 1 to 10 of 116
Thread: grandfather clock finished!!!
    Dec 2008
    falcon heights, minnesota
    5,610
    well, the last of the scheduled major projects has been started.
    today i made hay while the sun shone (expected rain today around 3, it got here around 7), and did it shine, 80 degrees and blue skies for most of today. yesterday i did a lot of the prep work, so that i could do the finessing with a passion. i cut the face frame parts for the clock box and lower case, and smoothed out the arcs of the sides of said face frames. i changed the method of construction, and found that i wasn't that far off to begin with. i wanted to simply butt the sides and top/bottom together, but the woodworker in me said no, that a rabbeted joint would look better, and so it was. i cut the grooves for the glass and the clock face/plywood backer, and discovered that i hadn't taken that into account when i did the sketchup drawing, so i had to adapt the design to the existing conditions. so, instead of 2 seperate hangers going to the supports, there will be one big (double thickness) support going to the supports. i would have gone on to the lower case, but after several hours in direct sunlight (can't get all my vitamind from milk ya know), i decided to call it a day. more to come, as it happens....
    Attached Thumbnails Attached Thumbnails clock box parts.JPG   clock box assembled 1.JPG   clock box assembled 2.JPG   lower case and shelf parts.JPG
    benedictione omnes bene
    www.burroviejowoodworking.com
    AWESOME!!!
    I'll be watching this one closely, this is on my list of things to do also!
    Go ahead and run clown, with those big floppy shoes, you won't get far.
    Sep 2007
    Central (upstate) NY
    1,457
    Very nice so far. Looking forward to seeing the end result.
    Catalunya
    4,632
    Go Danny Go!!
    Looks great so far, looking forward to see its evolution.
    Are you going to fit a mechanical movement or a quartz one?
    Best regards,
    Toni
    That is one project I've always wanted to do, but I doubt I ever will, my wife doesn't like the sound of a ticking clock and to me, that is the only reason to have one
    I'll be watching the build with interest for sure!
    Dec 2008
    5,610
    thanks guys, this is gonna be a fun one.
    toni, it will be a quartz movement, and i made sure to get one that goes off on the quarter, half, and on the hour (traditionalist in me i guess). i was also thinking about adding 3-4 holes (neatly lined up) so that the sound can escape the clock box.
    one thing i forgot to mention, is that this is going to be done in cherry, and finished like it's counterparts. naturally, with my sense of humor (humour for those in canada & england), i'm making sure that only the wildest of grain will be on all of the most visible surfaces.
    Dec 2008
    5,610
    today's progress
    not too much done today, not that much time. but i got the middle shelf, lower case back, and lower case top glued up today. who knows what tomorrow will bring...
    Dec 2008
    5,610
    forgot the pic...
    new york city burbs
    10,188
    dan, where do you get the clock movements and stuff?
    17,475
    well at least he has gotten outa the bed this time to work and even had a cold drink to help make threw the heat looks good dano
  1. My Grandfather is turning 100 tomorrow!
    Last Post: 06-23-2011, 03:39 AM
  2. grandfather clock idea for the state fair
    By Dan Noren in forum Designs, Plans and Sketches
    Last Post: 02-19-2009, 08:25 AM
  3. Plans source for a Grandfather clock?
    By Dennis Thompson in forum General Woodworking Q&A
    Last Post: 01-21-2008, 03:28 PM
  4. Grandfather Clock Finally Finished !!!
    By Ben Roman in forum Flatwork Project Showcase
    Last Post: 01-11-2007, 01:06 AM
  5. Grandfather Clock Finally Finished !!!
    By Ben Roman in forum General Woodworking Q&A
    Last Post: 01-06-2007, 04:41 AM
