Alex Reid
- Zushi, Japan
Thanks folks for all the comments. This project took about 4hrs to make. Definitely an anomaly in my workshop it was nice to start and finish in one session. I thought you guys would like this as it is an easy one to do and it brings nice results. A great stocking stuffer.
The base is 6mm (1/4") and the band is 2mm thick. I didn't have to steam bend but any thicker than 2mm and I would have had to apply heat. My wife asked if the side is strong enough because it is so thin but really it doesn't need to strong as it is only there to prevent the cookies from rolling off . I wouldn't go less than 2mm though.
One tip for those that want to make this. Make sure you keep your reference points for square. You will need them when it comes time to cut the handles on the TS.
