Results 1 to 5 of 5
Thread: Central AC vs Heat Pump for replacement AC?
    Indianapolis area
    1,697
    My AC unit is most likely on it's last legs. It's about 12 years old (Janitrol) and uses freon. I want to be ready when it gives up and quits. We have an 8 year old 92% (IIRC) efficient natural gas forced air furnace (Lennox in good condition). When it's time to replace the AC would it be wise to go with another AC or change to an air to air heat pump using the furnace as the back up. Any advise from the vast knowledge of the Family is most welcome! Around Indy the summers usually get to the high 80s or low 90s and very humid. The winters may go subzero for a few days; maybe more that once a season.
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
    Look at what your utility bill is in the winter when you use gas for heat . If it is definitely lower than your spring/ summer bill I would just replace the a/c. If the winter heating bill is higher then your summer cooling bill you might want to consider a heat pump. Just my 2 cents.
    37 5'16.25"N 7625'28.11"W
    193
    The heat pump would reduce your dependence on gas for heat for the moderate temps, but it's not a cure all. Heat pumps get really inefficient below about 30 deg or so. but you could use it for AC and heat for spring and fall saving on the gas bill. You'll also have to deal with the ducting issues too. AC ducts are generally in the ceiling as cool air falls as apposed to heating ducts which are in the floors so the hot air raises.
    Mike
    The Heart of Dixie
    4,268
    What touplin said. I wouldn't think it would be a good choice that far north but they maybe? AC part will work fine. Even here in the sunny south we have to use the backup heat in winter a few times each year. They just don't do well in cold weather. No heat in the air to steal.
    Custom built boats and Kits
    Feb 2009
    Whittier, CA, USA
    512
    Here is a solution you might consider - a geothermal heat pump system. Basically it uses the earth as the source of heat in the winter and as a coolant in the summer. A heat pump system looping through coils in the ground takes advantage of the earth's constant temperature below a certain depth. In a city or small lot situation you have to drilll down for the ground loops versus trenches where you have the space (drilling is more expensive).
    Initial cost is higher, but the more efficient transfer of energy to and from the earth means you will spend less money operating it. With construction services being in the dumps your cost to install should be a bit lower right now and grid energy costs never seem to drop right now would be a good time to look at these systems. Taking the longer service life of new quality equipment and possible energy rebates payback vs a conventional air exchange system is probably acceptable if you plan on staying in your house for another 7 years. I believe almost all of these systems are considered energy star compliant.
    I know I will use it in my house here in southern California when I do my addition/remodel.
    Here are some web sources for information -
    http://en.wikipedia.org/wiki/Geothermal_heat_pump
    http://www.consumerenergycenter.org/...eothermal.html
    http://www.energysavers.gov/your_hom.../mytopic=12640
    http://www.thisoldhouse.com/toh/arti...162296,00.html
    Cheers.
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
  1. Air Pump For Scroll Saw and other..
    By Paul Douglass in forum Jigs and Fixtures
    Last Post: 02-04-2014, 08:27 PM
  2. Vacuum pump
    By Darren Wright in forum General Woodworking Q&A
    Last Post: 03-04-2013, 07:41 PM
  3. Vacuum Pump
    By Chip Sutherland in forum Lathe Project Showcase
    Last Post: 03-03-2013, 04:30 PM
  4. Vacuum Pump
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 03-03-2010, 02:16 AM
  5. Vacuum Pump
    Last Post: 02-27-2010, 04:25 PM
