Results 1 to 10 of 16
Thread: Need help with my 10" wheel
    Constantine, MI
    7,890
    I have a Delta wet/dry grinder that I purchased reconditioned some years ago for under $100.
    The wheel was out of round from day one and, after several failed attempts to remedy this, I placed it all on a back shelf and forgot about it. I just pulled it out for another look. I have found a replacement wheel here for $45. Not a bad price. However, I was wondering, is there such a place as a service that will true up the wheel for me? What kind of business should I be looking for? As for doing it myself, it's really bad and probably worse because of my prior attempts. Best I should leave this to someone who knows what they are doing.
    www.wrworkshop.com
    May 2009
    Syracuse, Nebraska
    669
    Any machine shop in the area should be able to handle that. If were close by I'd do it for you. You also can pick up a diamond dress fairly cheap and dress it yourself. It isn't to difficult especially with a slow rpm machine like that. I have one just like it and use a Norbide Stick for dressing, but that is something I've had for about 35 years and use often as a Tool & Die Maker. That's about a $60 item these days. Another possibility is a near by Community College that offers Machining courses might do it for you. Good Luck
    Roger
    11,831
    Rennie, I think the real question is: do you really want to bother with that thing at all?
    I have had one of those for quite a few years and it has proven to be practically useless. It saw very little use for most of those years. Then, one day, I found the big wheel to be cracked. As you said, they are expensive to replace.
    I haven't shoved mine into a dark forgotten corner yet but also haven't been motivated to pop for the money either.
    Instead, you might want to consider spending yer money on a Wolverine jig and/or a Delta slow grinder.
    Constantine, MI
    7,890
    you make a good point - might be a candidate for Craig's list.
    www.wrworkshop.com
    Jul 2007
    Liberty, IN
    25
    Rennie, Do you know anyone with a Tormek grinder. Tormek has a nice truing tool. Maybe the wheel could be mounted on a Tormek grinder & trued up.
    Honolulu, Hawaii
    1,103
    rennie,
    Send it on over. I'll make good use of it (after I get it corrected)
    Really,,,No, really.
    I should be able to true up the wheel. I've done it on regular grinder wheels.
    Thanks for the link to the wheel source.
    Hey Frank, just what is it about that slow/wet grinder that you don't like? (aside from the cracked wheel) I might like to build one similar to the ones offered. I'd make changes in design if I knew what were undesirable features/designs/functions.
    Opinions and experiences are really welcomed.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Constantine, MI
    7,890
    Quote Originally Posted by Tony Baideme View Post
    rennie,
    Aloha, Tony
    OK - you're on! PM me with your mailing address and I'll try to get it out next week.
    www.wrworkshop.com
    Honolulu, Hawaii
    1,103
    Rennie,
    PM sent.
    Aloha, Tony
    Sarnia, Ontario, Canada
    55
    I have one like that but under another brand name - the worst purchase that I have ever made.
    Rod
    Sarnia, Ontario
    11,831
    rennie,
    Aloha, Tony
    Timing is interesting. I have to mount something on my all-purpose grinder/sharpening table today and the slow/wet monster goes. Into a dark corner never to be seen again.
    What I don't like: it doesn't sharpen. Difficult, bordering on impossible, to hold a correct angle for whatever it is you may be TRYING to sharpen. Slow/wet wheel is simply too fine a grit to do much more than polish an already sharpened edge. Found is barely OK for flat chisels to keep sharp. Cleaning the water tub is a real pain in the bizinkess too. About a year ago, after a period of no use and with a dry wheel, I found the big wheel cracked. Just did it all by itself. I am not motivated to spend the money on a new wheel since I don't like using it in the first place. Collecting dust is best use for this bow-wow by a long shot.
  1. SIMPLE JIG! turns a "bowl" on "tablesaw"!
    By steve kelly in forum Carving
    Last Post: 11-01-2015, 03:21 PM
  2. New 5th Wheel Rig
    Last Post: 06-10-2015, 04:12 PM
  3. "Crime Doesn't Pay" or "No Good Deed Goes Unpunished" ?
    Last Post: 11-21-2013, 05:57 PM
  4. Thompson "V" Versus "U" Bowl Gouges
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 06-25-2013, 01:46 AM
  5. On the "effective" grit of a wheel
    By Kurt Whitley in forum Turning Tool Questions and Show & Tell
    Last Post: 09-15-2008, 02:13 PM
