Results 1 to 8 of 8
Thread: Turning drawer pulls
    Apr 2009
    Outside the beltway
    5,262
    I pulled a 1790's Sheraton dresser down from the loft last week to restore for sale and didn't realize there were no pulls. I checked another Sheraton I have close to the same period to match up pulls. After no being able to locate any I decided to turn 2 top drawer [small] and 8 lower drawer large. This is the most finicky turns I've ever done. I have 1 small done and 4 large done and have busted just as many. Seems like cherry likes to bust allot. But they are looking period.
    11,834
    Congratulations on your perseverence.
    But, there are many, even most, old pulls, and whatevers, available as reproductions.
    VanDykes is one of the biggest, but there are others.
    http://www.vandykes.com/
    Otherwise, good luck with the turning. I'm working on some finials right now. The actual turning part isn't hard (I'm using mahagony, thanks, Tod) but getting identical is.
    Are you talking about Knobs?
    I tried making a bunch, a while back, you are right, Unless you are used to making bottle stopper and such you send more to knob heaven than you make, but after a while they catch on. I use a small faceplate with a piece of sacrifice wood attached . Through it I center a screw similar to the one I will attach the knob. Using the correct pilot hole I screw a small chunk and using smaller tools and high speeds, you can turn out a few good matches. The sacrifice piece allows you to come in close to the back side w/o damage to the tool.
    I have a couple of similar period pieces and the knobs are attached through Dowels these need a small chuck to complete or turn as the screw on knobs but drill out for a dowel. One of my Chests has a split dowel with a wedge to secure to the drawer (don't know if it was original or "Repaired" along it life.)
    Both are Shaker Originals (Shaker made Shaker style furniture, I was raised within 3 miles of a Shaker Village)
    Also, as Frank mentioned, I have always been satisfied with VanDykes Restorers, they will send you a great catalog if you order on line, Buy something and they will fill your mailbox with great wish books and ideas. ( I also buy from Vandykes Taxidermy and am a satisfied customer.)
    No connection here, just satisfied...
    North West Indiana
    6,101
    Dave I use a drill chuck from an old floor drill press (mt #2). So I turn a square piece round between centers, mark and do a lot of the prep (angle, back dowel, etc) then put it in the drill chuck and between the tailstock, cut it loose from the front end so I can bring my tool rest around and finish it up, do all my sanding and for some even friction polish only. Then cut it loose or almost loose and then go to the bandsaw. Works good for me this way. Tap your drill chuck in with a mallet of some type to "seat" it in. To stop it from working out or wanting to walk out, I do the back side cuts on the pull while the tailstock is being used.
    Jon
    Apr 2009
    Outside the beltway
    5,262
    I figured this out through trail and era, Using the old Shop Smith which has an attachment for such things. I cut the blocks, sanded off the square edges , that helped allot towards reducing the breakage and I sharpened the 2 chisels which I found did all the work. I could have bought the repro's but I needed a certain diameter for the base plus the look. Here is the Dresser, I have a little repair to do on the top.
    Attached Thumbnails Attached Thumbnails CIMG0051.JPG   CIMG0047.JPG   CIMG0048.JPG   CIMG0049.JPG   CIMG0050.JPG
    11,834
    OK, glad you figured out a technique and it worked for you.
    Of course, there is the added satisfaction of doing it for yerself.
    North West Indiana
    6,101
    Bang up job!!!! It is very satisfying to turn them yourself isn't it?!!!
    Jon
    Apr 2009
    Outside the beltway
    5,262
    Sure is Jon, after the initial trail era only 4 were broken and I finished up the remained 5 with no breakage. Now to finish the dresser with a hand finish.
  1. Bent lamination dresser pulls, process and results.
    By Dewayne Baker in forum Flatwork Project Showcase
    Last Post: 12-09-2015, 09:20 PM
  2. turning a maple drawer pull
    By Dave Hawksford in forum General Woodturning Q&A
    Last Post: 02-28-2014, 02:11 AM
  3. Shop Made Pulls
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 11-16-2012, 05:21 AM
  4. Over 10,000 Drawer pulls on this site.
    Last Post: 09-29-2010, 04:07 AM
  5. Replies: 0
    Last Post: 11-07-2008, 01:29 AM
