Results 1 to 10 of 22
Thread: Table critique (pics)
    Comments/criticism solicited on this little 'lamp table'. This is probably the first thing I can remember making where Jean said flat out she didn't like it. Didn't like the top, didn't like the legs sticking up, didn't like the crossed pieces at the bottom.
    This is a prototype, and I'm going to tweak it a bit... but I still think the general 'look' is fine. And I rather like it.
    What I think is the legs are a bit 'heavy' for the diameter of the top (16-1/2")... but I already had the top notched so it was too late to change. On the next ones I'll make the top 17-1/2 to 18", and cut the legs down from 1-3/4 to 1-5/8". I'm not sure I'm completely happy with the 'no apron' look at the top, but I'm also not willing to fiddle with a round one... so I'm particularly interested in thoughts on this.
    For what it's worth, this is mostly South American mesquite (Argentina) that I bought by mistake a while back. I think the cross pieces at the bottom may be honey mesquite (another mistake!).
    Sep 2007
    Central (upstate) NY
    1,457
    I wonder how it would look with the tabletop mounted so that the grain is diagonal to the leg lines instead of parallel and perpendicular to as made.
    There's too much pretty figure in at least that one leg to chop them down. Somethings some folks just aren't gonna like, that's why there's more than just maple trees used for lumber.
    Best of luck if you try it again!
    Dec 2008
    falcon heights, minnesota
    5,610
    i like it kirk it has a lot of interesting stickley features. the only thing different that i could see, is that i would agree with you about the legs being a touch slimmer, but the cross members as well. it would give it a lighter look.
    benedictione omnes bene
    www.burroviejowoodworking.com
    11,832
    It is what it is. Just fine.
    One could say their preferences might be different but they didn't build it. I would probably...here I go ....have made the bottom cross pieces a bit more delicate.
    And, how do you buy South American mesquite by mistake?
    If you really don't like. Cut up, ship the wood to me and I'll use for some knock-out delicious pen blanks.
    12,256
    Kirk, I saw the pictures first and read your post after. I actually like it all. So that proves if you aske many people you will get many different answers. Beauty is in the eye of the beholder.
    If no one wants it ship it to me. I will put it to good use in my own bedroom. Got just the spot for it. I like the heavy solid set and Mark symetrical is good for me.
    What finish did you use. Can you show a piece of the wood in the natural state just so I can compare the color before and after finish?
    Oh and I can see it on antique roadshow years from now........Some appraiser saying...."Ahhh that is a Constable I believe...characteristic of the period in the 2009 years"
    Jan 2008
    Austin TX
    405
    Kirk,
    What a cool little table! I like the design and the wood. It may be outside the box, for some, but I'm not one of them. It's a little reminiscent of one made by Gary Rogowski at Fine Woodworking, but I think yours stands on it's own.
    Good luck,
    Lee Laird
    Austin TX
    Quote Originally Posted by Mark Kosmowski View Post
    I thought about that, Mark... but I found the easiest way to cut the notches in the top was with a square blank (before cutting the circle). The square would have to be bigger to begin with to cut the same size diagonal out.
    And Frank/Dan, my preference would also be a little 'less' in the cross pieces, but the Stickley piece I saw that was very similar was very 'heavy'... so I compromised a bit. I will go a bit smaller on the next one(s).
    Sometimes it's hard to tell the varieties of mesquite apart... especially when everthing in the place is from Argentina. Didn't know that at the time... I thought I'd found a Texas mesquite bonanza. Color if the rough stock is close. Big tipoff was when I got home and saw the chalk writing on several pieces. There's some pretty figure in there.
    Rob, unfinished it looks much like African mahogany. In the picture I have WATCO natural danish oil on it. I may or may not put lacquer over it (might leave it alone since it's a practice piece).
    Thanks for the comments!
    London, Ontario
    3,383
    Kirk,
    First impression: I like it fine.
    But after reading your email in depth I looked a bit closer.
    1- it seems to me that the crosspieces are not flush. Is that an artifact of the photo or is one higher than the other where they meet? I'd make them flush.
    2- the pegs. I think it might look better if the two pegs were one above each other rather than diagonal where they pin the crosspiece to the legs. I also wonder if the top peg - which pins the legs to the top - would look better if it were the same size as the lower pegs. (or is than another photo trick? It sure looks bigger)
    If you make the legs smaller, I would still keep them thicker than the crosspieces.
    I might also try out shorter (in the vertical dimension) crosspieces -- or just make the arch more pronounced?
    These are all very minor points.
    best,
    ...art
    12,256
    Art, those are very good points you make. I learnt something from your comments
    Kirk,
    best,
    ...art
    The cross pieces aren't flush on purpose. I like to use a chamfer on every edge of my A&C things... and that little offset is equal to the chamfer. I've done it on a few other pieces, but I'm pretty sure it's not an original idea. That detail also also takes the eye away from any sloppiness of the joint there (bridle joint?).
    I made the pegs diagonal at the bottom on a whim. I offset them like that on purpose because there's really a dowel in there to pin the tenon and it lets me get the holes a little farther apart. Didn't think about the top ones until later. The top hole is bigger so I can get a screw in there. I'm not sure a screw is necessary... I may try one with just a dowel instead and use the smaller plug.
    Good comments.
  1. Cherry Table - Delivered - Final pics
    Last Post: 08-16-2011, 02:11 PM
  2. Picnic Table Finishing/sealer? Tips? *Pics*
    By Erin Reichelt in forum Finishing School
    Last Post: 08-17-2009, 01:53 PM
  3. Curly Cherry Hall Table W/Pics *Installed*
    By Jason Tuinstra in forum Flatwork Project Showcase
    Last Post: 01-23-2009, 05:47 AM
  4. update on wiring pics Table Saw Problem
    Last Post: 11-22-2008, 07:50 PM
  5. Drill press table with pics
    By Dan Forman in forum General Woodworking Q&A
    Last Post: 03-17-2007, 02:28 PM
