Results 1 to 7 of 7
Thread: Finishing
    3,134
    Finishing
    After rubbing down with steel-wool a surface finished with Poly Urethane can I spray lacquer over it?
    Honolulu, Hawaii
    1,103
    Finishing
    I don't think I would do that Bart. The solvents in the lacquer might penetrate the poly, especislly since you have sanded it, and cause lifting.
    You can apply poly over lacquer, but I have to recommend against the lacquer over poly.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Jul 2007
    Liberty, IN
    25
    It will not work.
    I use lacquer thinner to clean dried poly from my spray gun.
    best off stickin` to more nasty stuff (poly)
    Apr 2009
    Outside the beltway
    5,259
    Why would you want to, Is the sheen to dual ?
    3,134
    Thanks for the answers. Its more poly then.
    NO!Way Jose'
  1. Finishing
    By Dennis Kranz in forum General Woodturning Q&A
    Last Post: 01-29-2012, 05:12 PM
  2. Finishing up
    By Dan Mosley in forum Lathe Project Showcase
    Last Post: 01-28-2010, 04:16 PM
  3. 101 of Finishing
    By Dawson Mossman in forum Finishing School
    Last Post: 09-02-2009, 09:51 PM
  4. finishing help
    By patrick anderson in forum Finishing School
    Last Post: 11-29-2007, 08:14 PM
  5. Finishing Help
    Last Post: 10-03-2007, 02:52 AM
