Results 1 to 10 of 17
Thread: GRRRRRRRRR Not happy with my Nova1224-44
    Central Illinois
    936
    Here I am trying to finish a 14" platter. Installed a vacumn chuck to hold it. Almost have the back leveled and ready to sand and BANG! The lathe stops! What the !
    Open the belt compartment and the belt is stuck next to the housing. HMMMMMMMMMMMMMMMMMMMM. Mess around with it and find that the slow speed pulley on the motor side spins around without the rest of the pulley or motor moving. The one setscrew on the large end does nothing to help.
    The customer who wanted the platter wants to see it this Saturday. I'll have to take it as is and explain that there's more work to do. Hope he doesn't need it RIGHT NOW!
    Was unable to get through to Technatool service. U.S. office shuts down at 2:30 PM est. Hope they get back to me, but I'll have to tear the headstock down to repair.
    Bruce
    Bruce Shiverdecker - Retired Starving Artist ( No longer a Part timer at Woodcraft, Peoria, Il.)
    "The great thing about turning is that all you have to do is remove what's not needed and you have something beautiful. Nature does the hard part!"
    Nov 2008
    Tampa & NC
    432
    1224-44 ???
    Did you mean 1624-44, ? I have the 1624 and have never had any major problems with it.I did have a problem with the banjo comin loose on me an I called him up an he had me a new one over night.Hope you get it fixed OK,sounds like the pully broke apart.Tim is usually real good at getting replacement parts out to you,If you can get him 1st thing in the morn,he will ship it the same day.Good luck.
    Ken
    Central Illinois
    936
    Got through to Tim today. He's been very busy. He won't be able to get the replacement out till the 17th, plus 3 days in transit puts it at the 20th. This is the second problem I've had with my "1624-44" (oops on the 12224). The first was with the tail stock. The reason I'm ticked off is the timing. If it had happened this past winter, it wouldn't have been such a problem.
    I still believe that Nova makes good stuff!
    Bruce
    30,014
    Glad to see Tim's got you covered, albeit with a bit of delay. Sometimes it seem problems wait until the most critical moments to rear their ugly heads.
    North West Indiana
    6,098
    I'll give you $50.00 for it! (the lathe not the platter!)
    Jon
    I bid $51.01 for the lathe...
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    Dec 2008
    falcon heights, minnesota
    5,609
    $51.02, and i'll throw in larry's beard...
    benedictione omnes bene
    www.burroviejowoodworking.com
    North West Indiana
    6,098
    NO ONE ELSE BID!!!!!!!!!!!!!!! I want to see Dan actually try to get Larry's beard!!!!!!!!!! I don't know Dan, but do know Larry!!! I will retract my bid so I can place the fifty on Larry with odds so I can win and bid $100.00!!!!!
    Jon
    Dec 2008
    5,609
    you think that's not the real larry in his avatar pic? wonder where his beard went?
    Central Illinois
    936
    Update!
    I took the unfinished platter to the market this morning. Showed it to my possible customer and his wife. They said yes, not only to this one, but a second platter and a shallow bowl out of the same piece of wood.
    Here's what they liked!
Name:	First White Oak Platter.jpg
    And as I said, it's not done yet - needs some polishing and French Polish.
    Bruce
  1. Should not be a GRrrrrrrrr........
    Last Post: 06-02-2012, 06:56 PM
  2. happy passover, happy easter
    Last Post: 04-06-2012, 10:49 AM
  3. I am happy to be here
    By Martin Roy in forum Welcome and Introductions
    Last Post: 03-25-2010, 10:12 AM
  4. Happy Passover!!!!!!Happy Easter!!!!!!!
    Last Post: 04-09-2009, 11:02 PM
  5. So Happy I Could................
    By Jonathan Shively in forum Off Topic Discussion
    Last Post: 08-18-2007, 08:00 AM
