Results 1 to 6 of 6
Thread: Re Decks
    12,243
    Re Decks
    Hi All
    Anyone used this product before?
    http://www.swingpaints.com/1555.htm
    I see they have a marine version and i also picked up a sample to test from a recent ww show.
    I wanted to put it on the railings of my deck now that i have removed them, planned them and re stained them. Wood is cedar.
    Wanted to give the top of the railing a sealing over and above the stain to help with cracking and prevent splinters.
    Am i being crazy?
    Thanks
    any film finish you put outdoors or even exposed to direct sunlight will fail...it`s only a matter of time.
    with proper maintenance any ol` marine varnish will perform as advertised..(key words "as advertised")
    in otherwords ya` gotta keep after it, sanding, scraping and recoating as needed..
    an oil finish is much more forgiving.
    Sep 2007
    St. Louis, MO
    583
    Epoxy is particularly susceptible to UV degredation. If it were me, i'd avoid it for this application
    Paul Hubbman
    12,243
    Thanks guys. I will follow your advice.
    I will do an experiment and take a small unsused piece of cedar and coat it and place it on the deck out of the way and follow its progress for a year. See how this stuff bears up to the elements. I see that this particular company says they have a UV version for outdoor use.
    Apr 2009
    Outside the beltway
    5,250
    Only one way I have found to work well on new or raw wood and last;
    Apply 3 coats of Thomsons water seal, follow directions. after the finial coat you need to wait 36 hours for the finial cure. Then if your painting apply 2 coats of primer and then finish,
    Before I was a finisher I painted houses for 15 years. I experimented with allot of products. Thomsons has proven to work as a good sealer coat between paint and wood.
    Nanaimo B.C. Canada
    131
    Lightbulb
    Rob you may want to have a look at this article from Fine Woodworking ->
    The Ultimate Outdoor Finish
    The article talks about using a product called MultiWoodPrime
    Good luck
    Cheers! - Jim
  1. Anyone used Rustoleum Restore for decks?
    By Tony Baideme in forum Off Topic Discussion
    Last Post: 06-10-2014, 08:29 AM
