Results 1 to 6 of 6
Thread: revisiting sharpening wheel grit debate
    11,833
    The subject of what is the best wheel grit for sharpening turning tools comes up fairly often, both here and other forums.
    My input has always been the same. When I first started turning, we had a professional turner as a member of our club. He advised me to go with 80 grit. His reasoning was that 100 was too fine and would not sharpen well. And 60 was too coarse and removed too much steel and left a ragged edge. So, I bought an Israeli made blue 80 grit and have been using that for more than six years.
    Today, I finally installed my new Delta slow grinder with my Wolverine rig. It has a white 60 grit and a white 120 grit. I wasn't real happy about this selection. But on testing, I got a big surprise. The 120 sharpens just fine. I'm real pleased with what it does and how it does it. I tested the 60 on an old Buck skew made with 'cast steel'. It also did a quite nice job and, IMHO, did not remove so much metal as to risk disaster.
    The only puzzlement is that while sharpening with the 120, I could see white dust coming off.
    A while back I sorta chided someone (Stu, wuz it you?) who mentioned that his sharpening wheels had gotten smaller. Seemed a near impossibility to me.
    Of course, I know that sharpening/grinding wheels do have to get smaller with use. But, my grinder, that I use for real grinding, is about 40 years old and the wheels are not notably smaller than when new. In fact, I have measured and they are still 8". (mebbe a bit less)
    But, these new white wheels do seem to be of a more friable material than the stuff the grinders are made from. So, I expect, I can look forward to shrinking wheels.
    So, what is the best grit for sharpening turning tools?
    Actually, is there a best?
    12,258
    Frank having just recently set up my wolverine and done a fair bit of sharpening on my Delta 8 inch grinder i found i had the same experience you have. I have an 80 grit Norton white wheel from LV. It does seem very friable and very suseptable to changing shape. That was one of my reasons for posting a question recently about the wheel trimmers. This white stone seems very loose.
    Cannot comment on your main question though i am still too inexperience in the field of sharpening. I could look up what Mr. Leonard Lee says in his book which i have. But that would be another mans opinion albeit a real pro in my opinion.
    11,833
    We did thrash this out less than a year ago:
    http://familywoodworking.org/forums/...ad.php?t=10812
    Left with as many questions as answers.
    No doubt though, 80 is most popular.
    But, my limited experience with the 120 has changed my thinking.
    Now...wats this bizness with white and blue wheels?
    30,017
    ...So, what is the best grit for sharpening turning tools?
    IMHO, the 1000 grit wheel on the Tormek.
    Seriously, if I'm only re-sharpening an existing profile, and not trying the come up with a new shape for the tool, I prefer the finer grade stone. When I was using my Woodcraft 1750 RPM grinder on my gouges, I liked the results from the 120 grit wheel better than the 80 grit wheel. (I do still sharpen my scrapers on the 80 grit, though. I still haven't tried the Tormek method of raising a burr on a scraper yet.)
    Everybody will have a different preference. I'd say try a few a one will stand out as your favorite.
    Your mention of your 40 year old non-wearing grinding wheels sounds a lot like the wheels my granddad had on his grinder. It must have had some type of Kryptonite wheels, because you could grind a car into dust with no discernible wear on the wheel. It had never been dressed, so it was also so loaded with grinding residue that the wheel itself would set off an airport metal detector.
    Apr 2009
    Outside the beltway
    5,259
    I've tried everything over the years and 5 years ago I bought a Tormek, don't ask me what grit the wheel is what ever is the standard wheel that comes with it. All I know is I can make my chisels razor sharp with the follow up use of the leather strop. I had thought about getting a Japaneses wet stone for it but why, I already make edges sharp enough to draw blood just looking at the tools.
    Red Deer, Alberta, Canada
    618
    Here's another vote for the Tormek. Like Vaughn, unless I'm changing a profile I like the Tormek.
    Why has common sense
    become so uncommon?
    My Woodwork Site
  1. 6 X 80 Belts, two 60 grit, two 80 grit - SoCal - GONE.
    By glenn bradley in forum Classified Ads
    Last Post: 01-09-2013, 02:40 AM
  2. what GRIT?
    By larry merlau in forum General Woodturning Q&A
    Last Post: 09-01-2012, 10:28 PM
  3. On the "effective" grit of a wheel
    By Kurt Whitley in forum Turning Tool Questions and Show & Tell
    Last Post: 09-15-2008, 02:13 PM
  4. sharpening wheel grit preference
    Last Post: 09-12-2008, 03:26 PM
  5. SketchUp Templates--Revisiting the Subject
    Last Post: 10-22-2007, 09:13 PM
