Results 1 to 7 of 7
Thread: Variation in Tailstock
    12,262
    Well after the discussion shifted regarding Bernies idea and the mounting of his bowl and chuck into the tailstock to be able to mount a bowl in the longworth chuck, I though a new thread might be in order.
    Here are the pictures of the movement I experience in my tailstock
    First the test setupClick image for larger version.
Name:	tailstock test  setup.jpg
    Then move the tailstock to the leftClick image for larger version.
Name:	movement to the left.jpg
    Then move it to the right Click image for larger version.
Name:	movemen t to the right.jpg
    Sorry the pictures are not the best but you can see the movement on the bed by the point of the mandrel on the caridge bolt head.
    Guess none of you with decent lathes get this movement? Or am I wrong?
    17,475
    nope
    i dont have that much movement with mine rob couldnt resist
    12,262
    That comment could be taken very many different ways Larry if this were not a family friendly site. And i dont mind at all.
    Rob, when you tighten the tailstock down, does it always end up in the same position? I'm assuming you're only seeing this lateral movement when it's loose. Is that correct?
    12,262
    No Vaughn thats the problem. It does not pull it into a consistent spot. I can basically have it tighten wherever i want between a significant range.
    Sounds like you might need to add some shims to the base of the tailstock. I know it can be done, but I don't know the specifics about actually doing it. Lacking shims, the only other advice I have would be to get in the habit of always pushing or pulling the tailstock to the same side of the bed before tightening it. Sort of like a sloppy miter gauge on a tablesaw...if you always push or pull it to the same side, you can get consistent results.
    12,262
    Good idea the shims there Vaughn. Now you get me thinking maybe take it to a friend and weld a bead of welding on the edge and grind it down to a tight fit incrementally. Helps to share a problem. Here i was living with it thinking this is not correct. I am going to go to a decent machine dealer and check out some more up market lathes.
  1. Variation on the Oland Tool
    By Chas Jones in forum Turning Tool Questions and Show & Tell
    Last Post: 05-21-2008, 04:29 PM
  2. Hollow Form Variation
    Last Post: 03-13-2008, 06:14 PM
