Results 1 to 10 of 18
Thread: Craftsman lathe....any good?
    May 2009
    Lafayette, Indiana
    2,380
    I know that craftsman lathes are not the best but......are they any good at all? One for sale in my area for $75.00 includes two tool rests and tools.
    Tom, it depends on the model. Any pics or model numbers? r do you know the capacity? My first full-size lathe was a Craftsman with a 15" swing. I bought it used, and I turned quite a few decent pieces on it before I moved up to the Powermatic.
    If the one you're seeing is the 15" model, then the $75 price is a steal.
    May 2009
    Lafayette, Indiana
    2,380
    I think the guy said 12 x 36 with 4 pre-set speeds.
    OK, that sounds like one of their older models. Hard to say how decent it is. Some of the older ones were well-made (I think they were made by Atlas back in the day). If you've got $75 to play with, I'd say get it and try it. If you don't like it, I'm pretty sure you could sell it for what you pay for it.
    Of course, the lathe is the least expensive part of turning. It's all the other bits and pieces that will turn your wallet into Swiss cheese.
    May 2009
    Lafayette, Indiana
    2,380
    I e-mailed him. He said it's a " Craftsman Copycrafter, with a 1/2 hp motor.
    Tom
    May 2009
    Lafayette, Indiana
    2,380
    Here is his photo. I'm not to sure about this?????
    Attached Thumbnails Attached Thumbnails 3ke3p83l4ZZZZZZZZZ96i459d2728631712e7.jpg
    I found this over at OWWM......... >> PDF <<
    From what I can see, this is a fixture that attaches to a round bed lathe that is used for making a bunch of identical items, like spindles.
    I honestly think you money could be better spent elsewhere, unless you have the need to make a bunch of identical spindles
    Ask him for a part number, something like "113.249070" (the copy crafter Part number). This will give you a bunch more info.
    May 2009
    Lafayette, Indiana
    2,380
    Well...I went ahead and bought this lathe tonight. The deal was that it was the 12" lathe AND the copy duplicator. It was already mounted on a 6' long workbench as well. It also came with a set of tools and faceplate, and smaller tool rest. I thought it would be a good deal for me until I outgrow it. It also gives me plenty of time to look for something bigger (nicer). I should be able to now attempt some smaller bowls and such. It has some surface rust but I think it will clean up nicely.
    Tom
    Attached Thumbnails Attached Thumbnails Resize Wizard-15.jpg   Resize Wizard-16.jpg   Resize Wizard-17.jpg
    I think that you did "Okay" -- the next step in this process is to have "FUN"
    Many photos -- please!!!
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    With that copy attachment on it, it's sort of like a tube bed lathe with outriggers. It might help stabilize things a bit having the extra pieces in place. While it's not anything you'll be swinging big chunks of tree on, you'll get some experience out of it, and probably more fun than $75 worth of movie passes would generate. (And chance are, with some practice you can sell enough pens and bottle stoppers to cover the cost of the lathe plus some of the additional stuff you'll be buying soon.)
    Next step: Do you have a good way to sharpen your new chisels? Having truly sharp tools will make a big difference in the enjoyment factor.
    And don't forget to pick up a face shield if you don't already have one.
  1. My old Craftsman 103.23070 wood lathe
    By Roy Bauman in forum Old Iron
    Last Post: 05-04-2016, 12:42 AM
  2. Replacement variable speed belt for Craftsman wood lathe 351.217150.
    By Wesley Harris in forum General Woodturning Q&A
    Last Post: 08-20-2015, 03:46 AM
  3. Turning a bowl on an Older Craftsman tube lathe
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 10-05-2013, 09:24 PM
  4. Craftsman Model 351.217150 Lathe's Variable speed control broke
    By Dimitri Schreiber in forum New Tools
    Last Post: 08-13-2010, 09:42 PM
  5. Replies: 12
    Last Post: 08-28-2007, 11:07 PM
