Results 1 to 10 of 19
Thread: Formica on top of Formica
    East Freeetown, Massachusetts
    3,020
    Ughhh - don't even ask.
    I will remodel the kitchen "some day" but not this day.
    For now - I am going to just paint the ugly cabinets.
    NOW - I have an ORANGE formica counter top
    We hate it - and will some day replace it - buy I just cannot replace it now.
    I am thinking of just putting a new formica on top of the old ugly orange formica top.
    Do you think the contact cement will adhere to the old formica?
    810
    Sacramento, CA
    1,367
    I've heard of it being done - ain't never done it myself ... like John said, if it's free of grease and roughed up good, it shouldn't have any problem stickin'
    Jason Beam
    Sacramento, CA
    3,020
    Well I think I am gonna give it a try.
    I looked at some formica tonight - shoot anything is better than the orange.
    I will let ya know - it's probably gonna be in a month or so.
    Sacramento, CA
    1,367
    Moving at the speed of Leo :P :P :P :P
    *poke*
    Jason Beam
    Sacramento, CA
    3,020
    Yeah - you know me all to well.
    I still have a Kayak on the list.
    Sacramento, CA
    1,367
    S'ok - i still haven't touched those metal lathe tools ya sent me ... Soon, tho. The shead's nearly complete!
    Jason Beam
    Sacramento, CA
    Oliver Springs, TN
    1,726
    If it's the kind with the rolled edge on the front you might have a problem with the bend. If the front edge is square I agree with everyone else, clean, ruff, glue.
    3,020
    John - it is NOT the curved kind.
    Leo,
    I always try to go to the horses mouth so to speak - below are the suggestions from two manufacturers. When I did our counter, it was suggested that I first put down 1/4" MDF glued and screwed. Then having a "new" surface, apply the new laminate as usual. The big reason I was told to go the extra step was to prevent delamination if hot items are placed on the counter. I got this from two different counter guys. Most say it's overkill, but it's worked fine for 15 years of abuse.
    Good Luck!!
    Wes
    Wilsonart:
    I want to laminate over melamine or existing laminate can I do this?
    We do not recommend bonding to existing laminate or melamine covered surfaces (in fact, our warranty does not cover these applications) because they are non-porous and often prove troublesome. If you decide to try anyway, follow these five guidelines:
    1. Sand the entire existing laminate surface with coarse grit sandpaper and then clean the dust off. This creates scratches for the adhesive to grip into.
    2. Allow the substrates and the glue to warm up to room temperature before use and perform all bonding at room temperature.
    3. Ensure 100% of the area to be bonded is covered with an adequate amount of adhesive (see product label for specific coverage amounts); be especially diligent about coverage around the perimeter.
    4. Do not try mating the substrates together too soon. The substrates will be ready to bond when the film of glue on each substrate feels tacky when you firmly press your fingertip onto it. The glue is NOT ready to bond and must dry longer if the glue is still wet or if any glue actually sticks to your fingertip and creates a rubbery “leg” as you pull your finger away.
    5. After mating the substrates together, use a hand-held J-roller with as much manual pressure as you can bring to bear over the entire surface. Multiple passes are recommended.
    Formica:
    http://www.formica.com/publish/site/...urf%20Tech.pdf
  1. Painting over Formica?
    By Tony Baideme in forum Finishing School
    Last Post: 05-11-2011, 06:55 PM
  2. Formica advice needed
    Last Post: 11-24-2010, 04:42 PM
  3. Question about Re-Gluing Formica
    By Vaughn McMillan in forum Carpentry and Construction
    Last Post: 09-03-2010, 11:56 PM
  4. tired of formica so!!!
    Last Post: 02-12-2009, 10:58 AM
  5. Nervous about Formica
    By Jon Farley in forum General Woodworking Q&A
    Last Post: 05-05-2007, 05:17 AM
