Results 1 to 6 of 6
Thread: Nova 1624 issue?
    Carlyle IL
    350
    Nova 1624 issue?
    I have been meaning to post this for some time now, but ... welll........ you know........ stuff happens .........and one forgets.
    anyway. I awhile back I was turning my first bowl on the 1624. during the turning the spinning slowed and I heard noises from the pulleys/motor.
    It turns out that one of the pulleys shifted. I adjusted and continued but had the problem reoccur............several times thereafter.
    This seems like an easy fix, but it isn't. the pulleys keep moving.
    can any one help answer this problem/question?
    thanks
    joe
    Central Illinois
    936
    Call Nova and get it fixed! They will.
    Bruce
    Bruce Shiverdecker - Retired Starving Artist ( No longer a Part timer at Woodcraft, Peoria, Il.)
    "The great thing about turning is that all you have to do is remove what's not needed and you have something beautiful. Nature does the hard part!"
    +1 for what Bruce says. Their service is really good. I had this begin to happen once but caught it during a speed change; realigned, tightened set screws and no further problem.
    Good Luck, I'm sure Tim Giest will be a lot of help.
    Jerry
    Hardinsburg, KY
    277
    Jerry started down the path I was going to get on. Loosen the set screw, position the pulley, re-tighten the set screw this time with the medium loc-tite. That should solve the problem once and for all. If not Tim will get 'er done for you.
    Working flat so I can play round,
    Doug Miller
    Repentance Is The
    Prerequisite For
    Gods Forgiveness
    Carlyle IL
    350
    Quote Originally Posted by Doug Miller View Post
    Is this a common issue with this lathe?
    thanks joe
    Nov 2008
    Tampa & NC
    432
    Nova 1624 issue
    I have had mine for two yrs and never had a problem,but when I 1st got it,I went over it completly and checked it for alignment an loose bolts screws an whatever.I did recently have the little plate that holds the tailstock spindle screw in place keep coming out on it,so I called Tim an was gonna order a new one an he told be where a set screw was that holds it in place,problem solved.
  1. Nova 1624
    By Paul Douglass in forum Turning Tool Questions and Show & Tell
    Last Post: 06-10-2010, 03:32 AM
  2. Nova DVR or 1624-44
    By Bruce Shiverdecker in forum Turning Tool Questions and Show & Tell
    Last Post: 04-03-2010, 08:04 PM
  3. Nova 1624-44
    By Rich Aldrich in forum Hot Deals
    Last Post: 07-07-2009, 02:14 AM
  4. Who owns a NOVA 1624-44?
    By Matt Hutchinson in forum Turning Tool Questions and Show & Tell
    Last Post: 06-21-2009, 11:18 PM
  5. Nova 1624-44 Lathe
    By Bruce Lane in forum New Tools
    Last Post: 10-29-2008, 10:34 AM
