Results 1 to 10 of 16
Thread: Vacuum pumps........?
    15,811
    I recently found this deal..........
    Surplus Center <link
    $89.95
    1/4 HP Rotary Compressor Vacuum Pump
    New GAST 0523. Direct drive, oil-less, rotary vane vacuum pump. Motor is thermally protected and will restart automatically after the coils cool.
    SPECIFICATIONS
    • HP 1/4
    • Voltage 220 AC, 50/60 Hz, 1 ph.
    • Amps 1.5
    • RPM 1725
    • 4.5 CFM at 0 PSI
    • 3.6 CFM at 10 PSI cont.
    • PSI 15 int.
    • 0.5 CFM at 26" Hg max.
    • Ports 1/4" NPT
    • Duty continuous
    • Thermal protection on motor
    • Size 5 5/8" x 13 1/4" x 6"
    • Shpg. 31 lbs.
    Would this unit be good enough for a vacuum chuck on a lathe?
    Price is cheap, and they will ship to Japan.......
    Houston, TX
    363
    Stu, that looks like the one most folks are using. You'll want a filter. 26" is enough to suck the bottom out of a thin bowl, DAMHIKT.
    The Heart of Dixie
    4,268
    Dunno. But my dealings with the Surplus Center were very good. So I can recommend them.
    Custom built boats and Kits
    Stu,
    I think that is the unit that a number of others have used for their lathe set-ups. From what I have read, everyone has been happy. Either way, as Cecil said, 26" Hg is plenty.
    Naturally, Surplus Center has a bunch of other neat stuff - you know, since you're paying for shipping anyway . . . .
    Wes
    15,811
    Well the shipping via USPS, surface is $55, with a filter, $6 it comes to about $150, so I'm not sure if I will go for it or not.
    I've heard that a house vacuum will work, I've got one of those sitting here, it really sucks, so I'll give that a try first.
    Hi Stu,
    I thought I had heard somewhere of a air compressor vac setup that seemed pretty reasonable. You might google it unless someone else has a linky.
    George
    Found it.
    It's the Holdfast System
    http://www.packardwoodworks.com/Merc...cc-vc-holdfast
    George
    vac pump
    I got that very unit just before Christmas and just purchased a bunch of other stuff from JoeWW to build a vac press. Hopefully I'll get a start on it this weekend. I'll try to keep a photo journal and post a few progress pics, not much of a photog though.
    17,515
    oilless?
    wont that thing heat up to much without oil on a vacume press bill.i was told they need to run awhile like a day or so to get veneers to dry and set up. if it will work for veneering then perhaps i could use one i got some veneering to do and was headed towards a vacum press myself
    15,811
    Help me out here guys, found this on Yahoo here..........
    Rotary Vacuum pump
    0.01mmHg
    15ℓ/min
    1/8HP
    all for the sum of about $80, three hours left on auction, no one has bid..............
    Would this work for a vacuum pump on the lathe?
  1. Vacuum pumps ..help needed
    Last Post: 03-28-2014, 02:42 AM
  2. How much vacuum do I need
    By Dave Gallaher in forum General Woodturning Q&A
    Last Post: 09-27-2011, 04:37 PM
  3. Vacuum pumps
    By Mike Henderson in forum General Woodworking Q&A
    Last Post: 06-25-2011, 08:13 PM
  4. Vacuum Rig
    By Stuart Ablett in forum Jigs and Fixtures
    Last Post: 09-14-2007, 09:00 PM
  5. Vacuum Pumps........again.......
    Last Post: 08-13-2007, 04:57 AM
