Results 1 to 7 of 7
Thread: Sharpening Question
    Palm Springs, Ca
    1,167
    Sharpening Question
    I have this sharpening stone which is coarse on one side and fine on the other - came with my Jet wet grinder and was wondering if i could just hone the edge on the tennon tool by using this stone and just rubbing back and forth ? I have not tried to sharpen a tool like this with two angle edges and thought from the previous post i could just use this stone to keep the edge sharp.......
    Attached Thumbnails Attached Thumbnails Tennon-1 (600 x 450).jpg   Tennon-2 (600 x 450).jpg   Stone (600 x 450).jpg
    The stone you are talking about is the Dual surface stone grader: Dresses the wheel for both fine and course sharpening. The wheel surface not steel.
    Hope this is what you are referring to..
    Paul
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    Palm Springs, Ca
    1,167
    yes you are right and thank you for telling me.....ill need another type of stone....thanks
    30,008
    Dan, can you sharpen it on your grinder, just like you would any other scraper? (I can't see the profile real clearly in the pics.)
    Goodland, Kansas
    4,834
    I have that tool and just take it to the grinder.
    Bernie W.
    Palm Springs, Ca
    1,167
    Yes i can take it to the grinder but i thought i may lose the angles that are on it. It has two different angles and i thought there may be a better way to sharpen this to keep the angles exact. By hand and on a stone as someone awhile back suggested could be good to.
    Bernie has one and uses his grinder so im thinking it wont hurt if im careful.
    Cotswolds, UK
    629
    Clean up the top surface with a credit card sized diamond dresser, that way you don't remove a great deal of metal and maintain your side angles.
    Chas. just a traveller on the road of time.
    Bits & Pieces Gallery
    My Web Site
  1. Question about sharpening jigs...
    By Roger Tulk in forum Turning Tool Questions and Show & Tell
    Last Post: 12-01-2015, 02:49 PM
  2. Sharpening question
    By Tom Niemi in forum Neander Woodworking Q&A
    Last Post: 09-25-2011, 02:53 AM
  3. grinder and sharpening jig question
    By Tom Baugues in forum General Woodturning Q&A
    Last Post: 09-06-2009, 04:44 PM
  4. Sharpening question
    By Mike Henderson in forum General Woodturning Q&A
    Last Post: 05-12-2008, 01:17 PM
  5. Sharpening Question!!!!
    By Gord Rock in forum Turning Tool Questions and Show & Tell
    Last Post: 02-12-2008, 05:24 PM
