Results 1 to 10 of 11
Thread: Help identifying a saw blade
    Feb 2009
    Whittier, CA, USA
    512
    Hello All,
    My Dad gave me this mystery blade that someone gave to him with a bunch of junk blades.
    It is a made in the USA Deciban Professionals 10" diameter blade with a 5/8" arbor hole. The saw plate is steel .095" thick, brazed carbide cutters .130" wide with a flat top grind.
    I am guessing it is a type of metal cutting blade, any info would be appreciated.
    Cheers.
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    My guess would be the same as yours, but I'm pretty ignorant about metalworking tools. I'm curious to see what someone who actually knows has to say.
    lutefisk capitol, USA
    485
    Maybe for concrete?
    17,475
    according to google i also say its a metal cuttun blade, and probally a non ferrous one,, but it could very well be used for crosscuting and do a good job have seen them used for that in mitre saws.. it also might be a ceramic blade for cuttin tile.
    i use nonferrous blades in my chopsaws....takes a bit more power to push through the wood but they cut well and last quite a while.
    11,833
    Dale had same guess as mine. Stone, concrete. And, quite possibly it is a wet style.
    Stone or concrete blades I've seen and used were diamond embedded to cut stone or tile. They didn't use carbide for that. From the looks I'd say non ferrous metals is what its used for
    Easthampton MA
    6
    Quote Originally Posted by Dan Gonzales View Post
    Hello All,
    Cheers.
    Not guessing...applying logic and 35 years of Industrial Problem solving...
    Diamond would be for stone. Carbide won't work.
    Metal cutting blade would be more teeth and ATB/Triple chip with negative hook angle. I cut a lot of Non-ferrous on my table saw and that blade isn't even close to a Non-ferrous blade. I also have a blade to cut Ferrous on my tablesaw...not close either!
    24 teeth, Flat top grind. Positive hook tooth angle would be a rip blade for wood. Compare the description to the cataqlogs...
    11,833
    So, Dan....there you have it. According to all the posts above, your blade is an all purpose that will cut anything in the world.
    Feb 2009
    Whittier, CA, USA
    512
    uhhhh..... thanks?
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
  1. Help in identifying wood
    By Ian Miller in forum General Woodworking Q&A
    Last Post: 02-04-2012, 11:05 PM
  2. Help identifying Japanese hand planes
    By Matt Ducar in forum Old Iron
    Last Post: 06-13-2011, 10:08 PM
  3. need help identifying some wood
    By Dan Noren in forum General Woodworking Q&A
    Last Post: 04-24-2011, 08:34 PM
  4. Identifying Wood: Dumb Question of the Day
    Last Post: 10-04-2010, 02:29 AM
  5. Identifying Wood
    Last Post: 06-13-2010, 01:01 AM
