Results 1 to 8 of 8
Thread: Difference betweek MDF and Particle Board
    South East Michigan
    84
    I was in the local Borg today looking for some MDF for a radial arm saw table. The only thing I could find was something called particle board. Is this the same thing? Surely the Borgs should have MDF.
    East Freeetown, Massachusetts
    3,019
    No - particle board and MDF are totally different animals
    They do have "some" similarities - being that they are made from particles of wood - but the similarities stop there.
    MDF - is a much better material than particle board.
    So it depents on what you need to use it for.
    Watcha makin?
    30,015
    Kevin, particle board is made up of bigger chunks of wood than MDF. Here's a pretty good explanation of the difference:
    http://www.lowes.com/lowes/lkn?actio...SBMDFPart.html
    For a radial arm saw table, the MDF would provide a smoother surface, but assuming a decent frame underneath, I believe the particle board would be sufficiently strong.
    3,134
    My RAS Has particle board & then plywood on top.
    11,831
    Don't forget to toss OSB into the confusion mix.
    South East Michigan
    84
    Well, I guess it is another trip to the Borg again today to see if they have what I need. I hate going there because it is about 40 miles one way. Thanks for all the help on the differences between particle board and MDF. The website says they stock the MDF but I sure couldn't find it. This time I am taking a SKU number.
    2,784
    Kevin, my HD stocks 1/4", 1/2" and 3/4" MDF. Hope you find what you need. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    South East Michigan
    84
    Well it turns out that the reason I couldn't find the MDF at the Borg yesterday is that someone had been sorting plywood and covered up the MDF with what they didn't want without returning it to the proper place. I finally asked someone that worked there where the MDF was and even he couldn't find it for a while. In any case I got what I needed so this week I will get my RAS set up.
    By the way this saw was donated to me. It is a Craftsman that had never even been out of the box. My sister bought it for my brother in law and he never even opened the box. His loss is my gain. Lucky for me my sister never buys anything but the top of the line stuff.
  1. What is the difference
    By Leo Voisine in forum General Woodworking Q&A
    Last Post: 03-10-2014, 12:49 AM
  2. Vertical Chest Board and Chalk Board
    By Jeb Taylor in forum Flatwork Project Showcase
    Last Post: 02-25-2012, 10:56 PM
  3. laminating oak and particle board
    Last Post: 05-25-2010, 01:24 AM
  4. What's the difference?
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 10-05-2008, 10:34 PM
  5. Particle Meter Group Sale (expires 1/21/08)
    By Lee DeRaud in forum Hot Deals
    Last Post: 01-29-2008, 04:04 PM
