Results 1 to 3 of 3
Thread: A real transition...........
    15,811
    Man, I'm ready to pull out all of my hair!
    My planer had a shroud or a transition I just slapped together when I got it, it was poorly built and was just supposed to be a stop gap, well that was some time ago
    I went to use the planer to dimension the walnut for the display humidor, and the shroud thing just simply collapsed........
    OK, time to get out the paper, and the compass and make a much better transition, or shroud.
    I found this page TRANSITON and followed along and the results are not bad............ the second time
    Can anyone spot my little whoops......
    Yep, kind of in the way.......
    I'll solve this this a wedge shaped piece that will fit in there..........
    ..............like this.........
    .........I'll make it one solid piece, so I can easily lift the lid to change knives.........
    Oh well, I'll get it done, but man, I'd rather be making chips and working on the darn display case.........
    Steve Clardy Guest
    Oops!!!
    I did that once with my molder.
    I sat back and was slapping my back some. Finally got the chips under control on this beast.
    Next day or so, I changed the knife profile, stuck some wood in it, and--
    Wood was stuck on the shroud end.
    15,811
    OK, I got it done!!!
    There is the wedge, worked out fine.......
    I retained the ability to open the top with just removing one screw.
    Some Akagashi that I planed, some "Junk" pieces......Looks fairly good eh?
    This is the walnut, I think it should be fairly nice.............no?
    OK, back on track........
  1. first real wood real cribbage board on cnc
    By Dan Noren in forum Computer-Aided Equipment Project Showcase
    Last Post: 07-12-2015, 04:52 PM
  2. Stanley Transition Plane
    By Dennis Ulrich in forum Neander Woodworking Q&A
    Last Post: 04-10-2012, 11:05 PM
  3. transition pieces - All done!
    By Mark Kosmowski in forum Flatwork Project Showcase
    Last Post: 11-03-2007, 09:47 AM
  4. making flooring transition pieces
    By Mark Kosmowski in forum Carpentry and Construction
    Last Post: 09-04-2007, 02:29 AM
  5. Transition Strip Question *Done*
    By Matt Dunlap in forum Carpentry and Construction
    Last Post: 08-28-2007, 05:55 PM
