Page 1 of 9 12345 ... LastLast
Results 1 to 10 of 81
Thread: Recession/Depression low cost workbench...UPDATE June 13 2010 progress report
    12,251
    Hi all, well i am at a stage of woodworking where pretty much have the big tools and most of the little tools but every time i start a project i find myself needing some other jig i dont have.
    This week its a workbench. I had to stop work on my Walnut project (to be posted another day) because i found myself working on the edge of the table saw fence. Thats when i said enough.!
    So when Matt started on about workbenches i decided to build one of the plans i sent him from Popular Woodworking. Its called the $175 woodworker workbench but i hope to come in even less since i was given a nice old vice (pic later) to put on my bench.
    This bench is a clever design using plain old pine from the borg (HD) and using a size where you get no waste. Total number of lengths required is 8 lengths of 2x8 12ft long. Pic out the best and cut to size. Glue up and voila workbench.
    So part one here are the pictures to prove.
Name:	2x8x6ft all milled up.jpg
ID:	34135Click image for larger version.
Name:	All cut down the middle wait i see a bench top forming.jpg
ID:	34136Click image for larger version.
Name:	First five slabs in glue up.jpg
ID:	34137Click image for larger version.
Name:	First of 4 slabs to make up the top.jpg
    Will update as progress I have just glued up slab no3 hope to get this done by the end of the weekend.
    Dec 2008
    falcon heights, minnesota
    5,609
    hmm, for $175 i could build 7 of the ones that i built, granted they would be without casters...
    benedictione omnes bene
    www.burroviejowoodworking.com
    12,251
    Progress Update
    Hi All
    Well after a little detour down idiots lane, I am back at it with the bench. As you can see from my vise post i did not stop progress while i sorted the jointer issue out.
    So here are all the slabs all planned and jointed and waiting glue up.
    I plan on making a drilling jig to drill and place a few dowels in each slab to try and keep them in line when gluing up.
    Any comment to that idea being worthwhile or fruitless excercise? This is what i thought out not part of the budget plan.
    See pictures of progress of slabs all stacked together.
Name:	Slabs all glued up and jointed.jpg
    Hopefully I get to make some real progress this weekend. This was supposed to be a 30 hour project...Not!
    Rob, that is one designed by Christopher Schwarz, so it will be a good bench, I'm sure you will get years of use out of it.
    A couple of very simple mods I'd make to that bench, make sure you put dog holes in the clamping caul that will go on the traveling face of the vice you use, and make sure you have a set of dog holes that line up with the holes in the vice caul.
    Then, buy at least two of theses............
    >> Holdfasts By Gramercy Tools <<
    and maybe a couple of these......
    >> Wonder Dogs <<
    You bench will become your favorite tool in your workshop!
    Bellingham
    2,449
    What, no mention of possible using biscuits for this? What is the matter, afraid you will get the whole 'Biscuit Joining" thread started again? Coward!
    12,251
    Thanks Stu
    And Bill you just gave me some real good Friday . Thanks.
    Oh yes i thought about biscuits....but i prefer the ones i eat with choc chips in them....yes (cookies to you) biscuits in real english.
    Seriously I thought the dowel would be more stable than a wobbly low depth biscuit.
    17,471
    rob if yu use square dowels or pegs it wont roll around on yu while tryun to glue up the top....
    499
    I really want to build one of these so keep the pictures coming.
    The last picture of the top looks REALLY GREAT !!
    Now I understand the post about the jointer.
    This is going to get really heavy.
    30,008
    Quote Originally Posted by Bartee Lamar View Post
    ...The last picture of the top looks REALLY GREAT !!...
    My thoughts exactly. I've got an old rolling cabinet with a similar "butcher block" benchtop on it, but the top is old (it was my granddad's) and in need of replacement. I may just have to see how affordable a few 2x4s would be and try something similar myself.
    As far as the glue-up, if the slabs are decently flat, I'd skip the dowels or biscuits and just use cauls at both ends to keep things aligned long enough to clamp it all up.
    This is not drawn to the right scale for your project, but it'll give you the general idea:
Name:	Panel Glue-Up Cauls.jpg
    I use wax paper under the cauls to keep them from sticking to the glue-up.
    499
    I think I agree with Vaughn.
    I have the Christopher Schwarz workbench book. I just looked at the Roubo bench. He gives no advice on how to glue the intermediate slabs. Just make sure you leave the clamps on some extra time.
    So I think you need to get something under them that is FLAT. that would be two 2x4's that you sight in like winding sticks. ( Not sure if winding is correct word. ) Then use cauls like Vaughn's picture.
    Good luck and let us know that you do.
  1. Five Talents June 12 Update
    Last Post: 06-13-2014, 03:54 PM
  2. Shopsmith Mark V 510 update 12/27/2010
    By Ned Bulken in forum New Tools
    Last Post: 12-27-2010, 08:05 PM
  3. Finally some DC progress to report......
    By Ken Fitzgerald in forum New Tools
    Last Post: 02-25-2008, 03:14 PM
  4. My new Griz progress report
    Last Post: 01-24-2008, 08:05 PM
  5. Progress Report
    By Bruce Page in forum General Woodworking Q&A
    Last Post: 08-04-2007, 06:28 PM
