Results 1 to 10 of 10
Thread: Modern/contempry trim
    Floydada, Tx
    1,941
    Question Modern/contempry trim
    Mods, if this belongs in carpentry please move. I have been aske to make som clean line simple moldings for a remold job. Problem is the cleints do not have any pics of what it is they want. Any one have pics of some? I have looked on the net, but have yet find any decent pics of profiles. These cleints have a mix of orginal(circa1865) fixtures and modern. Any ideas?
    Jan 2009
    Central New Mexico
    6
    I've always liked the look of simple rectangular casings, sized to be in scale with the other trim in the house - usually 3" wide x 5/8" thick. The face corners are usually rounded just a bit (less than 1/8" radius) thus some suppliers sell it as R.E. casing. If this is too plain, you might look for an oval faced casing where the face surface is a section of an oval. This gives a more contemporary look that may not fit a house with 1865 era fixtures. The RE casing can be dressed up a little with a simple backband to make it more traditional. Anyway, my $.02 - good luck.
    A typical base moulding I would use would would be 4" tall with a 1/2" groove 1/4" deep that's 1/2" down from the top. It's clean and gives a nice shadow line. You could do the same thing but make it taller. Depending on if new drywall is being intalled you can set it flush and it's really clean.
    You could then run a similar profile as door casing and get really clever and make sure the groove from the base runs up and around the door. Alternatively you could use a simple rectangular profile but cut a 1/4 x 1/4 rebate in the back edge where it meets the drywall and get a nice shadow gap detail.
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
    Floydada, Tx
    1,941
    Thanks, I will make up a few samples tonight to take with me.
    Southern Louisiana
    947
    Al, that is the look we went for, kinda a traditional modern clean look
    check out the pics here.
    http://familywoodworking.org/forums/...t=10260&page=6
    let me know if you have questions about some of the trim.
    chris
    Floydada, Tx
    1,941
    Loves good Chris. How tall is that cove molding? I like the way you tied the modern and old together. What are the header above the windows and doors?
    Being a modernist architect I would avoid the cove as that goes back to old school but if you like it then that's all that matters.
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
    Southern Louisiana
    947
    patrick, i suggested it because he mentioned their mix of old and new.
    i think if you're doing "true" modern trim, crown molding is not needed. not in any mod homes i have seen anyway.
    by the way i love your neosheds, way cool!!
    cheers mate.....just need to find some people to place orders and I'll be happy
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
    Floydada, Tx
    1,941
    Well after a few samples and tossing around different Ideas. They are going with this profile http://www.woodmastertools.com/NS/ac...il.cfm?PID=185. It is great when they pick a profile I already have. Thanks all for the help.
  1. Danish Modern?
    Last Post: 07-14-2014, 05:37 PM
  2. A Modern Console
    Last Post: 09-23-2013, 10:18 AM
  3. Anyone For Mid-Century Modern
    Last Post: 07-16-2012, 12:29 AM
  4. Modern Longworth Chuck
    Last Post: 09-14-2011, 03:13 AM
  5. Modern Marvels - Saws
    By Sean Wright in forum Off Topic Discussion
    Last Post: 07-19-2007, 08:15 PM
Tags for this Thread
