Results 1 to 7 of 7
Thread: Fibonacci Gauge project
    499
    My good friend David asked if I could make some parts for a Fibonacci Gauage he found seraching the internet. His church is doing a summer family week. He is using this gauge for the kids to find the golden ratio in nature. It occurs frequently in plants and flowers.
    This is from WOOD magazine #173. Found it here
    Finding the binding posts took a little luck. I could not find binding posts so I thought I would try pop-rivets. My Google for pop rivets got me to Hanson Rivet and Supply. So Hanson had binding posts buried in their product lines. I was able to get exactly what I wanted.
    The trick here is you need 1/8" thick x 1/2" wide strips of wood. I tried this on my band saw and was not happy.
    So I then decided to use the table saw, with a 30 tooth glue line rip blade. Using my grippers it worked great. I used a zero clearance blank for dado blades on my SawStop. I removed the riving knife and just had a zero clearance for the blade. It worked GREAT. I had no trouble cutting this very small strips.
    I got the 1/8" gripper leg from Peachtree Woodworking
    After cutting LOTS of little pieces, I needed to put holes in them. LOTS of holes. So I used my Pinnacle drill press table to set up the repeated holes. This is not an exact process. Lots of trial and error. But I did suceed and it worked great. The really good bits from Lee Valley did a great job.
    Next I needed to put points on 3 of the 4 pieces. I created a template and marked all of the pieces. Then used the 6" belt sander to grind away. It worked very well. I really appreciate my dust collection now.
    Here is what I ended up with.
    And it even looks like the picture.
    The really cool part is that it works.
    This was a fun few hours in the shop. It's really nice to have all of the tools to do a project that will be fun for the kids.
    Here is the web album with a few more pictures
    Constantine, MI
    7,888
    I saw that project in WOOD a while back and thought it was a neat one. Glad it worked for you - they came out great.
    www.wrworkshop.com
    11,825
    May I brag?
    You also saw it here.
    http://www.familywoodworking.org/for...ead.php?t=3885
    Tellico Plains, Tennessee
    4,351
    Bartee,
    Pretty cool... thanks for the tutorial...
    I had to look and see if you were from a Yankee work shop and a good old Southern boy... your tutorial sounded like Norm Abrams for a minute there
    Chuck
    Tellico Plains, TN
    499
    Chuck,
    Good ole southern boy....
    Watched way too much of Norm.
    And I seem to enjoy the sharing part.
    30,008
    They came out looking great, Bartee. I don't really use it often, but the Pinnacle fence and stop system on the drill pretty sure is handy sometimes. (Mine's the red version of the hardware in a homemade table.)
    And just so you know, if you use the 1/4" Grrripper leg to cut 1/8" strips, you have a 1/8" Grrripper leg almost immediately. DAMHIKT. No harm, no foul...carbide cuts right through the plasticm but it probably voids the warranty.
    oswego county , upstate n.y.
    280
    And just so you know, if you use the 1/4" Grrripper leg to cut 1/8" strips, you have a 1/8" Grrripper leg almost immediately. DAMHIKT. No harm, no foul...carbide cuts right through the plasticm but it probably voids the warranty. [/QUOTE]
    nice job bartee
    what are you building today ??
    GRIZZLY
  1. Used a .410 Gauge
    Last Post: 12-19-2013, 10:53 PM
  2. Replies: 0
    Last Post: 04-16-2012, 01:43 PM
  3. Marking gauge conversion kit to mortise gauge
    Last Post: 09-03-2010, 03:55 AM
  4. Fibonacci gauge
    By Frank Fusco in forum New Tools
    Last Post: 05-21-2007, 11:47 PM
  5. Fibonacci Gauge
    By Frank Fusco in forum Jigs and Fixtures
    Last Post: 04-08-2007, 11:48 AM
