Rob Keeble
- GTA Ontario Canada
Hi All
I hope someone here is wise enough or has a grizzly type jointer that has a similar fence to mine. G586
I set it up at 90 degrees and then joint the edge of a board and after its out of square. So thinking something is loose i tighten up all the cap screws etc again and reset and the same issue.
So now I am mystified. Dont know where the problem is coming from but I am getting mad because i jointer a wedge out of my slab of pine i have glued up for my workbench.
Been trying to get the edges of the various slabs square before gluing them up together as a single top.
Something aint right here. Even with the fence not 90 I should not be making a wedge.
Okay hit me with everything you got I need the help and asap i am burning daylight. Will get on with another task in the meantime.
Thanks in advance for any guidance
