Results 1 to 10 of 12
Thread: Two Toboggans (illustrating steam bending techniques)
    Toronto, Ontario, CANADA
    2,332
    (post 1 of 2)
    Early in 2005 I created a thread on Saw Mill Creek about building a toboggan for my granddaughter Jamie. At the time I made that toboggan, I bent sufficient slats for a second toboggan and this year I built that toboggan for my grandson Ethan.
    Here a thread that contains much of the stuff from the original thread augmented by material about the new toboggan.
    In early 2005, I attended a toboggan making course at my local Lee Valley store. It was a two part course. During the first part, we steamed and bent the wood then, a week later; we took the wood off the forms, and assembled the toboggans. Everyone attending the course exited with a toboggan and, for a small additional charge to cover material, I exited with the bent wood that will allow me to build a second toboggan in the future.
    The main purpose of the course was to learn to steam and bend wood, producing a toboggan was just a bonus. The course was taught by John Robinson who is a well known Windsor Chair craftsman. John teaches chair making classes in both Canada and the USA and some of his chairs have been featured in Fine Woodworking.
    We made the toboggans with relatively green ash that John cut on his bandsaw shortly before the course. The boards were about 3/8 inch thick and about 2.6 inches wide. According to our coarse notes, kiln dried wood should not be used. Here is a quote from the notes:
    Kiln-dried wood must not be used; the lignin in the wood has been permanently set during the hot dry kilning process. No amount of steaming or soaking will weaken the lignum bond sufficiently for successful bending. The same applies for air dried wood that has been allowed to dry and stabilize below 10% moisture content.
    The toboggan making process is best illustrated with pictures.
    1) We first marked the ash to show best orientation and position of cross pieces. Then we planed the edges and scraped the sides a bit. Next, the boards were placed into the (home made) steam box.
Name:	Toboggan Making -1 -small.JPG
    2) The boards were steamed for about an hour. Here is another view of the box.
Name:	Toboggan Making -2  -small.JPG
    3) The boards were (very carefully) bent over a circular form. The form is made of PVC pipe about 8 inches in diameter.
Name:	Toboggan Making -3 -small.JPG
    4) Then, they were tied down. That's John Robinson in the background.
Name:	Toboggan Making -4 -small.JPG
    (5) Finally, the boards were clamped in a couple of places. This assembly was allowed to dry for a week.
Name:	Toboggan Making -5 small.JPG
    The second part of the course was straightforward scrapping, sanding, and assembly. Then finishing was completed at home.
    6) This is a photo of the toboggan as it was when I brought it home.
Name:	Toboggan Making -6 -small.jpg
    7) In this photo, I am burning Jamie's name into the toboggan.
Name:	Toboggan Making -7 -small.JPG
    8) The next step was to finish the toboggan with 3 coats of clear Varathane and with two coats of wax on the bottom. This is a photo of taken after that stage (along with the second toboggan still in the form).
Name:	Toboggan Making -8 -small.JPG
    Cheers, Frank
    2,332
    (post 2 of 2)
    9) And, here is Jamie’s toboggan decked out with ropes and a pad and all ready to go.
Name:	Toboggan Making -9 -small.jpg
    10) Now turning to 2006. In December, I finished the other toboggan for my grandson Ethan (4.5 years old). First, I needed to sand the slats.
Name:	Toboggan Making -12 -Frank sanding inside of a toboggan slat -small.JPG
    11) Next, I needed to make the cross pieces (out of scrap maple). Here the slats are being fitted into the top cross piece:
Name:	Toboggan Making -13 -Fitting the slats in Ethan's toboggan -small.JPG
    12) Now the toboggan has been assembled and Ethan’s name is being burned into it.
Name:	Toboggan Making -14 Burning Ethan's name into the toboggan -small.JPG
    I did split one of the slats a bit when bending it two years ago, and that is a Bondo patch at the curve of the send slat to the right.
    13) And here is the finished toboggan, along with other gifts, outside Ethan’s house on Christmas day.
Name:	Toboggan Making -15 -Xmas Day -Our presents waiting inthe Harris driveway -small.JPG
    Unfortunately , we are not getting a decent winter in Toronto this year, so Ethan has not had the opportunity to use the toboggan.
    Cheers, Frank
    Thanks for sharing Frank. Next time it snows here in the Phoenix area I might need to make one of them..
    2,332
    Just in case anyone complains that this is not flatwork, I figure that it is more flat than curved, so this is the best place to describe the project.
    Cheers, Frank
    Well it sure ain't spinney work.
    30,231
    Cool projects, Frank. It looks like Jamie is quite happy with her new toboggan (pic #10). That picture is worth way more than a thousand words.
    Steve Clardy Guest
    Looks great Frank.
    810
    Frank ... Wow !! They are fabulous. Your description of the process was very enlightening and is something I'd like to try someday. Your grandkids will have something to remember you by forever.
    Thank you for posting this!
    15,815
    Great post Frank, and that little guy sure is one lucky kid!
    I sent a link to my brother, he is an industrial arts teacher, and they are making toboggans at school this year!
    Eaton Rapids Michigan
    40
    Thats neat Frank, That will have to go on a to list. You may have jinx the snow gods. We got the grandkids snow boards last year and sleds this year and haven't had enough snow to use them yet. At least they won't get worned out.
    Bill
  1. Steam bending for boat building with a clever non steam box idea
    Last Post: 04-27-2015, 04:50 PM
  2. Steam Bending Revisited
    By Dan Mooney in forum General Woodworking Q&A
    Last Post: 05-25-2010, 05:12 AM
  3. Steam Bending Question
    Last Post: 05-19-2010, 11:13 PM
  4. Steam Bending ?
    By Don Baer in forum General Woodworking Q&A
    Last Post: 08-04-2009, 04:56 PM
  5. Steam bending or laminating stripes, when, how and why?
    Last Post: 08-24-2007, 02:14 PM
