Results 1 to 8 of 8
Thread: bathroom sink
    new york city burbs
    10,184
    bathroom sink
    quick questions,
    If I purchase a new bathroom sink, (it goes on a vanity, small, tiny vanity, tiny bathroom), does it matter what I mount the sink on?
    Can I just mount it into the plywood panels of the cabinet?
    Do I need to lay a piece of waterproof board(cement board) on top of the plywood and cut a hole through it to lay the sink in?
    I see alot of the junk sold at big stores are basically particle board with veneer on top, does it matter what lumber I use for cabinets if I wanted to go with solid wood?There has never been a water problem as in flooding. No tub in room.
    Apr 2008
    We now divide our time between southwest Florida and southwest Vermont.
    137
    Allen: I assume you're using standard size cabinet and sink top. The few times I've done that, I just laid down a generous bead of adhesive caulk on the top edge of the cabinet, set the sink top down on it, and let it set up overnight.
    Tony
    The optimist says the glass is half full.
    The pessimist says it's half empty.
    I say the glass is twice as big as it needs to be.
    5,317
    You gonna tile the top, or what?
    If you're tiling, do that first, then set the sink on top of the tile, using a bead of silicone caulk to seal the sink to the countertop.
    new york city burbs
    10,184
    no, Im going to build a base cabinet for the sink, just not sure if Im mounting it over the sides of the cabinet, or into the top. Not sure if the sink itself will be the surface, or if Ill purchase a cheap stone top for all cabinets same height.
    5,317
    Is this a sink/countertop combo, like they sell at Home Depot, etc. in standard widths like 32", 36", etc?
    If so, then you don't need a top on your cabinet - just put it directly on.
    Feb 2009
    Michigan, Usa
    9
    Allen if you're using a marble like top with a molded sink you can set it with siclone or latex caulk on the top of the plywood sides and set the top right into the sealant. If you're using a drop in style china sink you'll need to either install a ceramic tile type top or a plastic laminate top would also suit your needs
    Allen,
    I'd go with plumbers putty especially if you might want to try a few things out. It will seal the edge, but is also removable.
    FWIW,
    Wes
    new york city burbs
    10,184
    thanx for the responses, this project was scheduled for second after I finished up the shop reorg.
    I need to make a coffee table as a gift for SIL and BIL, and then I was going to tackle the bathroom, but my wife would prefer me taking a break for the rest of the summer, and after that I need to rip down some wall paper and attempt to rip down a small staircase wall and put up a small wall near the bathroom. Then painting and molding, then the vanity for the bathroom.
    Like I said in one thread, my time is allotted for the next 10 years as far as woodworking and home improvement work.
  1. Trap for Your Shop Sink
    Last Post: 02-21-2012, 01:02 PM
  2. Vanity top and sink question
    By Ron Jones in forum Off Topic Discussion
    Last Post: 10-03-2010, 02:10 AM
  3. what do I use for cabinet/sink vanity walls in small bathroom?
    By allen levine in forum Carpentry and Construction
    Last Post: 05-24-2009, 08:12 PM
  4. Sink in the Shop - Priceless
    By glenn bradley in forum Carpentry and Construction
    Last Post: 04-15-2009, 03:44 AM
