Results 1 to 10 of 20
Thread: Finally Completed Dust Collector Install!
    Dec 2008
    Nixa, Mo.
    60
    I finally completed the installation of the Grizzly G0548Z 2hp Dust Collector. It was quit a chore. I ran all the ducts as you saw before and I now have the Twin Trashcan Cyclone Separator. Everything seems to be working like a charm and I am very happy with the outcome. Just need to wire for Static electricity.
    Dust Collector next to Twin Trashcan Separator
    New Dust Collector!
    Inlet Ports with Blast gates for Router and Radial Arm Saw!
    Twin Trash Can Separator!
    My plan is to learn to build furniture and I am going to be self taught.
    15,809
    Your ducting looks good, but I think you will loose a lot of CFM with the trash can seperator
    When you upgrade to a cyclone, your well done duct work will really pay off
    Dec 2008
    Nixa, Mo.
    60
    I won't be upgrading to a cyclone.
    5,323
    Your ducting looks good, but I think you will loose a lot of CFM with the trash can seperator...
    I doubt you're losing much, if any, air volume from the separator, but one small improvement might be made by turning your DC 90°. That way, you'll eliminate one of the 90° bends in the flex hose going from the separator to the DC. It'll give the air a straighter, smoother path.
    Dec 2008
    Nixa, Mo.
    60
    I will see if I can do that Jim thanks for the advise.
    13,464
    Looks really nice Gary. Can you post some pics of how the garbage can separator is built? Just curious...thanks
    Dec 2008
    Nixa, Mo.
    60
    Darren, It is just the standard Trashcan Separator that Phil Thien shows on his site. The only thing I did was cut the bottom out of the top can and then fabricate a holder to set on the bottom of the top can and hold into the bottom can. I used 6" Fittings in the top is the reason for the extra can to catch the dust in. Next time I break it down to empty it I will get you some pictures.
    The cabinet might be just in the way.
    5,323
    Quote Originally Posted by Kirk Constable View Post
    Kirk,
    In the first pic, it looks like there oughtta be enough room - maybe...
    Quote Originally Posted by Gary Lange View Post
    ...It is just the standard Trashcan Separator that Phil Thien shows on his site...
    Gary,
    Does it have the plywood baffle like Phil uses on his smaller collector, or is it just an open cylinder? Just curious.
    Dec 2008
    Nixa, Mo.
    60
    It has the baffle in it Jim. That's why I cut the bottom out and put another can under it. Gives me a little capacity.
    I am thinking about moving the cabinet so I can shift the dust collector around and get a straight shot into the fan.
  1. Dust Deputy vs. HF Dust Collector
    Last Post: 06-29-2015, 01:54 PM
  2. Queen Platform Bed - Completed - Finally!!!
    By Bill Arnold in forum Flatwork Project Showcase
    Last Post: 04-16-2014, 06:24 PM
  3. Do you use your dust collector?
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 07-06-2012, 01:36 PM
  4. Your dust collector
    By Mohammad Madha in forum Off Topic Discussion
    Last Post: 02-03-2011, 02:57 PM
  5. Another Dust Deputy Install
    Last Post: 12-27-2009, 03:09 AM
