Results 1 to 10 of 14
Thread: Carter Bandsaw Stabilizer
    Apr 2008
    Butte Montana which is 1/2 way between Purgatory and Heaven
    170
    Has anyone have experience with the Carter Blade Stabilizer?
    I know there is an old saying about why shut the gate after the cows get out, well maybe I should have asked this question BEFORE I bought the stabilizer!
    I have a 17" Grizzly, and I'm a little confused and unhappy about the way this fits. It could be me, but I'm hoping to get someones view on the product..
    Thanks
    Jiggs Elphison
    11,833
    Watizzit? Pictures please.
    Apr 2008
    170
    Carter Band Saw Stablizer
    Here is a link - check out the video
    http://www.woodcraft.com/family.aspx?familyid=20342
    Jiggs Elphison
    11,833
    Interesting. A new thing to me. Looks like it decreases the throat height by an inch or more. And, the sample photo in the ad has the wood going backwards.
    My first blush is that properly adjusted guides do just fine without spending $80.00.
    9,077
    Which 17" Griz do you have. I was told by Carter via email a few weeks ago that there was not a stabilizer offered for my G0513X.
    Apr 2008
    170
    I have the G0513 - I called Carter direct 1-888 622-7837 ext 11- name: Kip
    they have one buts it requires an adapter - Total cost 139.00
    Jiggs Elphsion
    12,264
    Jiggs just a return to normallity here, i watch the video on woodcraft and after looking at all the other bits and pieces offered by carter to tune up the blade the thought occurred to me as to how much more i would spend to supposedly tune up my Delta bandsaw that has done me no harm todate.
    Can i ask you what is it that you are experiencing as a problem that led you to wanting to put these accessories onto your saw in the first place?
    Maybe there is more than one way to tackle the problem.
    Interesting. A new thing to me. Looks like it decreases the throat height by an inch or more...
    It replaces the other guides, so I suspect there's no loss in throat height. As I understand things, it's essentially a guide for thin blades.
    5,323
    There IS about half an inch of reduction is sawable height, and the stabilizer is intended only for use with 1/16" ~ 3/16" blades.
    You install it it place of the upper guides. It slides into the guide mounting hole, just like the OEM guides, and is adjusted to put a small forward thrust on the blade. You open the bottom guides up so that they don't touch the blade at all.
    This makes the end result a blade that's very slightly forward of vertical - the cut at the top of the workpiece begins maybe 3/32" before it contacts the bottom of an 8/4 piece. Supposedly, it make 'scroll-type' work easier. (See my tag line, below)
    I've had one of these for my 14" saw for probably ten years. While it doesn't make the saw cut any worse, it doesn't - for me, at least - seem to provide any significant improvement, either.
    I very seldom use mine. In fact, if somebody wants one badly, I'll sell mine for half the going price. It the one made for Jet/Tai-Chi 14" saws.
    Apr 2008
    170
    Rob Keeble asked me "Why did I think I needed it?"
    I have to shamefully admit I am a habitual GADGET or GIMMICK buyer. I may die broke, but you'll be able to open a museum with all the useless gimmicks I've purchased over the years.
    If I were to stay off the internet I'd be better off. I see something new or something that is suppose to be easier and better than what I have I have to try it. 90% of what I get is JUNK!! or I find that it's not as good as what I have.
    I'm trying to make bandsaw boxes. On the forum that didn't want me to join because of my name, I saw a post where someone was using it and a half a dozen comments that were all favorable of how great the stabilizer was.
    I checked it out on the internet, and you know the rest of the story.
    Anyway I did install it. Does it work? I guess but I really think I could live without. On my saw it's time consuming to install it.
    Jiggs Elphison
  1. carter stabliser
    Last Post: 04-23-2014, 04:15 PM
  2. New Monster Laser Arm Stabilizer
    Last Post: 03-10-2010, 02:58 AM
  3. Carter accurite bandsaw blades
    By Alan Bienlein in forum New Tools
    Last Post: 01-26-2010, 03:25 AM
  4. Stabilizer
    By Bill McQueen in forum General Woodworking Q&A
    Last Post: 09-04-2009, 01:39 AM
  5. Carter quick release bandsaw tensioner?
    By Wes Billups in forum New Tools
    Last Post: 01-08-2008, 05:10 PM
