Page 1 of 42 1234511 ... LastLast
Results 1 to 10 of 417
Thread: Garage/shop rearrangement
    new york city burbs
    10,184
    Garage/shop rearrangement-FINAL REARRANGEMENT, FOREVER
    Mostly for convenience, but also for my safety.
    Having large machines immobile besides my main TS, have become troublesome for me.
    I have tripped accidently twice the past month, and its mostly do to the small area and grouping of machines, the mitre stand always blocking the entrance, etc.
    As mentioned, my eyes dont function the correct way anymore, I can see fine, but when the muscles tire, the peripheral vision stinks, and I spend so much time concentrating on my vision, seems I dont see below or to the sides well.
    Anyway, as everything else in life, its just a small obstacle that I will live with and setting my shop up accordingly is a must, right now.
    First, I removed any cabinets that were in an area I needed for something else.
    Not much in those cabinets anyway. The cabinets along the front wall on right were taken out, I built a lumber rack up to the roof.
    The lumber rack on the left side is now gone.
    I moved the bandsaw all the way to the front left corner, where it will be easy to run dust collection lines, and only roll the saw out a couple of feet if Im resawing longer boards.
    I purchased a lift table on sale at harbor freight, I keep the planer on it, so I can move it to center of garage when I need it and wont have to lift it up anymore, the lift table will lift it to table height, then Ill just slide it over, like a sick patient from gurney to bed.
    I will park the lift table next to the bandsaw, underneath a folding shelf I will use for the new left extension of the new sliding mitre, Makita, 10 inch.
    The sliding mitre will be at same level as the new work bench will be, the mitre to the left of the bench. Permanent position. I was going to build a mobile base stand with fold down wings, but the mitre in that position along the left wall will be another easy dust collection hookup for me.
    I removed the tall narrow tool cabinet next to the old work bench, so I can make the work bench a bit wider,(and deeper), and still have adequate room for the sliding mitre.
    I will then build a new sub table,(on strong castors) under the work table, that will house several drawers to hold most of the electric handheld tools, and the small wrenches and screwdrivers, etc.I will also put a small wood vise on the portable work table since Im sick and tired of trying to figure out ways to clamp down wood on its edge when I need to plane a bit.(or need to hold something to chisel out a bit)
    The rolling sub table will not be as wide as the work table, I will leave enough to put in a new rolling router table. I will be purchasing a Porter Cable router for this table, but this is last on my list.
    The jointer will stay on the far wall in the back, as it was, the compressor will be put on a small cart, Im building that this weekend, using the plywood from the cabinets and rolling table I have now, that Im going to dissassemble.
    Im going to use the 2.5 inch castors I have on the rolling table now, for the air compressor cart. I purchased 5 inch urethane red rollers for the new rolling table.
    I also purchased(at harbor freight), and pneumatic hose reel to keep the hose neat and in place because it has become a hazard for me not seeing it and knowing its a accident waiting to happen.
    Ive put some planning into this.
    new york city burbs
    10,184
    I believe I covered everything. Oh, when I first got the pancake compressor, I used an old kiddie wagon to roll it around on, then put it in the back of the garage.
    The wagon rotted away in the yard. I checked the tires, they are fine, sprayed some lubricant on the wheels, built a plywood frame/box, out of the wood I saved from the ripped out cabinets,and made a scraps bin, a rolling bin, something else so I can move it out of the way when I begin each day, or park it out of my way.
    Too much scraps, too many bins, too many hazards for me.
    The old redwood and cedar scraps, pressure treated, I finally had to part with.
    It wasnt really usable, not for furniture, maybe to make plate holders or napkin holders, but I dont think Id get around to it anytime in the future.
    The walls where I had all the scraps stored, in between the studs, will now house 4 inch shelves and hold all the hardware and spray, cans, glues, whatever I had stored in the cabinets I tossed.(much more space withthe small shelves, I must utilize every sq inch)
    some pictures of where I am right now, I didnt get much done today, besides ripping out the tool cabinet, I purchased the mitre saw, I needed to take a break from the shop this week. I have chased out all the spiders, and some of them were not too thrilled I gave a good clean up.
    As I worked, I ran the dust collector with a few open hose ends, just to clean as much air as I could since I really kicked up old dust today when I got down to the studs and base.
    makita mitre saw note-I am holding up the left fence and how it flips over.
    The right fence is not the same height, and I was a bit ticked off that the high right fence is an accessory, and runs 29 bucks. I got it for 15, but it didnt make me much happier. Makita should throw it in.
    I went with Makita, it was that or Hitachi. both have the most stable sliders, the double bar, but I believe while I was comparing them, Im pretty sure Makita has more ball bearings. Both got good reviews, both designed well.
    I havent used it yet, but theres a smooth turn on, and if Makita would like a review, I can tell them where to send my check, I do not promote any product unless it performs like a master in the hands of a amateur like myself.
    Btw, the 99 dollar Ryobi mitre Ive used for almost 3 years, kudos to Ryobi.
    The machine was used as much as a commercial shop, and still performs top notch, I just wanted the option of cutting 12 inches at 90 degrees.
    The stand will not be used and I will put both away and just hold on as back up.
    Attached Thumbnails Attached Thumbnails wood stuff 1022 (Medium).jpg   wood stuff 1024 (Medium).jpg   wood stuff 1025 (Medium).jpg   wood stuff 1026 (Medium).jpg   wood stuff 1028 (Medium).jpg
    wood stuff 1030 (Medium).jpg   wood stuff 1031 (Medium).jpg   wood stuff 1032 (Medium).jpg   wood stuff 1033 (Medium).jpg
    new york city burbs
    10,184
    last pictures, the compressor as I said will be on a mobile cart this weekend.
    sorry about the long post, wanted to include everything I planned out.
    I have not yet ordered any dust collection additions.
    I might go with some type of metal ducting for the main ductwork along the walls.
    Ive been watching and waiting for used sliding mitres, there arent many, and Ive never seen a makita or hitachi used for a decent price.
    Attached Thumbnails Attached Thumbnails wood stuff 1023 (Medium).jpg   wood stuff 1027 (Medium).jpg
    new york city burbs
    10,184
    almost forgot one of the better upgrades:
    My son has had this old dell laptop for a while.
    Its around 6 years old, not in use but he formatted it for me, cleaned it up, put sketchup on it, and I liberated these sliding brackets from the dumpster years ago, used on some type of computer equipment, cabinets that slide in, I have a few sets of them, going to install a sliding laptop holder shelf under the top of the rolling table, and have a shop computer.
    My wife says all I need is a toilet and a bed and I never have to come inside anymore.
    I told her Id need airconditioning and a fridge if she wants me out of her hair completely.
    Attached Thumbnails Attached Thumbnails wood stuff 1035 (Medium).jpg   wood stuff 1037 (Medium).jpg
    London, Ontario
    3,383
    I see your problem, Allen. It's right there in that first photo. You've just got way too much wood.
    Seriously, that is a pretty big stash!
    ...art
    12,243
    Hey Allen it must be something in the air right now. I just performed the exact same excercise last weekend. Even though i built myself a dedicated shop, i started to tackle projects (motivated by this forum) before i had fully organized my shop. Foud myself falling and tripping over all sorts and it was getting to be a tight sqeeze just to move around. I too said enough especially when you get reminded of the hazards when someone here posts an accident.
    Good for you on the clean up. Hey as for aircon keep an eye out for specials. I picked up an 8000 BTU unit from the HD for $100 Canadian.
    When it gets to August they start to look at clearing stock.
    Like your wood rack thats my project for this weekend if i can get to the shop. Then i can get back to finishing my bench now that the clutter is out the way.
    Great looking saw you just bought. What made you want the 12" cutting. I found I actually want to sell my DeWalt slider because its too big. But I think your Makita can have the sliders all the way in and still be used as a chop saw correct? So its does not have to take up the full width to be able to be used for narrow wood. Is that right?
    Good luck with the clean up.
    Constantine, MI
    7,887
    Oh sure, blame us!
    We all die. The goal isn't to live forever; the goal is to create something that will. - Chuck Palahniuk
    www.wrworkshop.com
    Apr 2009
    Outside the beltway
    5,250
    Good Job Allen, it's in the air. Mostly I think because a lot of shops are slow and to keep busy we make changes.
    new york city burbs
    10,184
    no lack of work here, not that I make a living doing it.
    Ive planned enough projects to keep me busy forever.
    I just needed to prepare the shop in a way that makes my life a bit easier, more productive. everytime I have to move this or that, then move it back, then back again, Im spending 40 % of my shop time moving things, and not cutting or building.and like Ive mentioned, hazards for me are unnacceptable at this point, the machines themselves offer me enough challenges, I dont need to trip over an air hose and crack my head open on the jointer(just missed last week)
    30,002
    Mine's about due for one of those, too. When it gets too cluttered to move around, it's time to de-kludge and reduce the size of the piles.
  1. Garage, er, Shop of Solitude
    By Dan Gonzales in forum Shop Tours
    Last Post: 07-22-2010, 11:44 PM
  2. Finally back in the (garage) shop
    Last Post: 02-23-2009, 01:31 AM
  3. New Garage - Shop build
    By Tom Hoffman in forum Carpentry and Construction
    Last Post: 07-04-2008, 05:01 PM
  4. Small Shop - Seeking rearrangement thoughts
    By Art Mulder in forum Shop Tours
    Last Post: 04-11-2008, 12:28 PM
  5. My mobile garage shop
    By Dewayne Baker in forum Shop Tours
    Last Post: 01-09-2008, 05:03 AM
