Results 1 to 5 of 5
Thread: Skip Tooth Bandsaw blade
    I read somewhere that a "Skip Tooth Blade" is the blade to use when resawing on a bandsaw. Would appreciate comments on the use of one. Also how many TPI would be optimum.
    Thanks, DKT
    3-4 teeth per inch as wide a body as your saw can tension...(don`t rely on sales literature for the saws ability to tension a blade)
    Sep 2007
    Shorewood, WI
    97
    There is a good document on resawing at the Highland site:
    http://www.highlandwoodworking.com/i...n=Custom&ID=19
    Mar 2009
    Lincoln AR
    142
    The thing is having as few teeth as possible in the work as possible. The fewer the teeth the more saw dust is removed. Lots of teeth gives a smoother cut but the saw dust remaining in the cut slot causes heat build up and even wandering, hard on saw too. Just remember to leave a little undercut to allow for planing or sanding.
    Nov 2008
    Tampa & NC
    432
    Skip tooth bandsaw blade
    For a board 8" max height the woodslicer from HT does a great job.After that they don't do so good.I know I have been using them on a 7 1/4 BS for about 4 yrs or more and they did great,BUT I got another BS and raised it to a 13" resaw capacity 1st thing I did was get the woodslicer BAD MOVE at 9" an over it is worthless,as it will not track at all.So I am going with Lenox blades for the big guy.
  1. Bandsaw Blade ?
    Last Post: 03-28-2015, 08:41 PM
  2. Bandsaw Blade
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 01-09-2010, 01:26 AM
  3. Ridgid 10" 90 tooth titanium blade
    By Jack Lemley in forum New Tools
    Last Post: 04-02-2009, 12:03 AM
  4. FS -- Delta 9" 40-tooth blade -- Brand New
    By Mark Rios in forum Old Ads
    Last Post: 11-11-2008, 05:24 AM
  5. Replies: 1
    Last Post: 02-28-2007, 11:55 AM
