Results 1 to 7 of 7
Thread: Priceing Question
    Floydada, Tx
    1,941
    Priceing Question
    For those that either work in a millshop or own one, how do you charge for milling rough lumber? Seems to be two groups that I have found. First are the ones that go by the board as it comes in and then the ones that charge for the finished board plus a little extra. Which way is more fair for both parties? At current I get $0.80 bft for milling their lumber, which is about the going rate.
    I've seen it both ways. One place I use charges me and hourly rate with a 1/4 Hr min.
    Floydada, Tx
    1,941
    What was their hourly rate?
    milling how al?
    s4s, rough random width/length to crown, how deap or wide if you`re talking cutting a profile, then profiled on how many sides....
    species makes a difference too i won`t cut hickory for the same price as poplar.
    Floydada, Tx
    1,941
    Tod, I do mostly moldings followed by s4s and then flooring. Still trying to figure out the best way of makeing the flooring.
    al,
    most moulding takes a minimum of 5 passes through the machines unless you`ve got a moulder with 5-6 heads....throw in the fact that shops with "real" moulders have gang-rips and laborers....a one man shop can`t s4s for 15cents bf.....that`s what my wholesaler charges me......but they come to me for curved stuff..
    setting up for short-run stuff can occasionally be profitable but move to 80cents a lf instead of bf.
    Floydada, Tx
    1,941
    Thanks Tod.
