Results 1 to 5 of 5
Thread: Glue for Natural Edge Bowl
    I am planning on tackling my first natural edge bowl this weekend. I read a few places that said you should put a small bead of glue where the bark joins the wood to help ensure that it does not chip off during your turning.
    Does anyone else do this? If so, what type of glue do I need to use? Do I need an accerant for the glue?
    Thanks.
    Jul 2007
    DSM, IA
    5,719
    Dawson, some bark won't come off...it's a gamble each time. Wood harvested in the winter tends to keep bark on better. I've used CA glue to hold bark on, but don't use the accellorator as it tends to turn the glue white. If the bark does come off, and you can find it, you can also use CA to glue it back on.
    Good luck and make sure to post pics of the bowl too.
    My Website
    When do you apply the glue?
    30,017
    Dawson, for the times I used thin CA glue to firm up the bark, I apply it after the bowl has been rough turned and dried, but before (or during) the finish turning.
    That said, more often than not I don't use any glue at all, unless a piece breaks off and I have to replace it. In those cases, I either find the missing piece, or I make a new one out of bark scraps and CA it into place. With a little work, the repair can be invisible when it's done. One other hot tip: A woodburner works great for touching up (darkening) small areas where a little bit of the outer bark has flaked off, and for camouflaging glue joints after doing repairs.
    Palm Springs, Ca
    1,169
    I use CA glue also to strengthen up the bark after roughing - works very well - I have also used black colored epoxy to fill in minor placesl, coffee gounds and pc's of bark. I have also used black colored pigment to dab and hide small areas.
    I guess it all depends on what your looking at and what i think at that time will work best........
  1. Natural Edge bowl warp
    By Dawson Mossman in forum General Woodturning Q&A
    Last Post: 04-25-2010, 03:48 AM
  2. Mesquite natural edge bowl
    By Dennis Kranz in forum Lathe Project Showcase
    Last Post: 03-06-2010, 02:16 AM
  3. Natural edge elm bowl
    By Dennis Ford in forum Lathe Project Showcase
    Last Post: 06-27-2009, 11:29 PM
  4. First Natural Edge Bowl
    Last Post: 02-12-2008, 09:17 AM
  5. Natural Edge Winged Bowl
    By Jim Ketron in forum Lathe Project Showcase
    Last Post: 01-29-2008, 06:03 PM
