Results 1 to 10 of 13
Thread: Ambo (Pulpit) Design
    Well as you may know I have the approved design for the Altar and now need to get serious about the design for the Ambo. Dan I tried the front panel solid with the edegs angled but it just didn't look right. I took Renee's suggestion and made the place for the book adjustable in height and the angle.
    As always your comments and suggestions are welcome.
    I am planning on putting something on the front like a dove
    This is the ambo placed in the santuary along with the altar.
    Attached Files Attached Files
    Constantine, MI
    7,887
    Hi Don - I like where this is going. However, the legs seem really heavy to me. I know you want to maintain a 'family resemblance' with the altar, but can the legs be downsized a it to lighten them up?
    www.wrworkshop.com
    Dec 2008
    falcon heights, minnesota
    5,606
    i agree with rennie, the legs need to be lightened up a bit. i would go with either 1 panel with the angled sides, or 2 with angled sides. i can't put my finger on it, but the 3 don't seem to work quite well visually. go with similar, but not carbon copy, that's what i did with the coffee, end, and sofa tables i made for one of my co-workers. all 3 had items that tied them together, but each was a seperate design. it needs the top, it just doesn't look right without it. you can still do the height/angle adjustment, but run it through an opening in the top. this can be done with a post that is in 3 parts, with the inner one tightened in place with a carriage bolt/wing nut, or even a series of holes with a nicely turned dowel to adjust the height, then the actual book holder can be adjusted with carriage bolt/wing nut. hope this helps....
    benedictione omnes bene
    www.burroviejowoodworking.com
    Quote Originally Posted by Dan Noren View Post
    I looked at 1 panel and it realy looks clunky. I look at the two panels but to me it sort of represent the trinity.
    In terms of lightening up the legs , I'll give it a try. I'll post a few examples. I tried the legs streight and it just didn't work.
    Here is a close-up of the altar amabo together. In the Picuture the Altar leag are 3" wide and 8" at the base. The ambo is 2 " x 6" at the base.
    Well I'm sorta stuck and open to ideas. I don't care for the open design of the top this piece. The pastor doesn't want the ambo too big so that it dwarfs the altar. I can adapt the raising and lower as well as the angle adjustment to just about any design. Here is the direction I was going in but just not happy with where it's going. HELP.
    Dec 2008
    5,606
    how's this look don?
    here's an idea for you to kick around.
    ummm dan all I see is a smile ...
    Dec 2008
    5,606
    grrrr... hit the wrong button...
    Dec 2008
    5,606
    the book holder on the top can be loose, and moved around to suit the person reading, and i left the back open in for shelves, drawers, cable tv monitor...
  1. Need some help with this design
    By Tom Baugues in forum Designs, Plans and Sketches
    Last Post: 10-18-2014, 08:07 PM
  2. Building the Ambo (lecturn, podium) - Final Picture
    By Don Baer in forum Flatwork Project Showcase
    Last Post: 07-29-2010, 03:11 PM
  3. New design
    By Jeff Horton in forum Designs, Plans and Sketches
    Last Post: 02-07-2010, 04:52 AM
  4. Ambo (Pulpit) Design
    By Don Baer in forum Designs, Plans and Sketches
    Last Post: 07-23-2009, 12:40 AM
  5. Joinery Question for pulpit base
    By Stephan Postmus in forum General Woodworking Q&A
    Last Post: 10-20-2008, 01:34 PM
