Results 1 to 5 of 5
Thread: Small Bandsaw DC Improvement
    We get threads on this now and again. The man in brown brought me a piece of rigid flex hose (free shipping from LV) so I finished this off.
    I keep some misc. parts around for such things but the hose was what I needed.
Name:	BS DC 001.jpg
ID:	34795Click image for larger version.
Name:	BS DC 002.jpg
    Just getting the hose in the general area underneath seems to do the trick.
Name:	BS DC 003.jpg
    Drilled some holes in the throat plate which helps quite a bit. This is the original 1970 plate. I need to replace this with a ZCI (and then drill holes in it).
Name:	BS DC 004.jpg
    This little guy stands in a row with my spindle sander and a couple of DPs. They all trigger the vac and I just move the hose (lower left of first pic) from one to the other as required.
    30,008
    Looks good, Glenn. Where does the lower hose attach? Is it coming into the bottom of the lower wheel housing?
    12,247
    Great idea the holes there Glenn. Not sure it would work for me on my Delta 14" the plate is very small. Is there any particular reason you hook these machines up to a vacuum rather than your DC?
    Correct. The 1970's Delta has an open bottom in the cast frame shape and the stand has a rectangular opening as well. It's an odd little saw with a cast frame and table, plastic-composite wheels and fiberglass covers.
    I cut a hole in a scrap of 1/2" ply to fit the pipe attached it from below the stand frame. If it hadn't had an opening already I would've cut a hole and attached something to the lower rear area of the cover.
    The DPs and small sanders get better pickup with the high velocity of the vac (I do the same on the CMS but it doesn't get used much). The small BS just happened to stand in the same line so in his case, it was convenience. The 17" gets a similar treatment but is on the cyclone.
  1. Think this will be an Improvement?
    By Charles Hans in forum Off Topic Discussion
    Last Post: 01-15-2015, 07:52 AM
  2. Sander Mobile Base Improvement
    Last Post: 10-03-2014, 03:15 PM
  3. Some improvement
    Last Post: 05-26-2014, 06:42 PM
  4. Improvement
    By Victor Skellett in forum Neander Tool Questions and Show & Tell
    Last Post: 08-16-2010, 11:08 PM
  5. Sanders dust extraction improvement
    Last Post: 08-12-2008, 08:44 PM
