Results 1 to 6 of 6
Thread: Sorby Tear drop scraper
    Kaneohe HI.
    70
    How is this scraper sharpened. Up till now, I have used a diamond offset mini hones to sharpen the top of the scraper. Looking at the round scraper that the Multi tool hollower from Sorby comes with , the sides are sharpened to a slight angle. Should'nt the Tear drop be sharpened with a slight angle also?
    John, I don't have the Sorby scraper, but the scraper bits with my Monster system are similar. I sharpen them just like a regular handled scraper.
    These pics show a tool bit being sharpened, but I use the same grinder setup (and the same angle) for my scrapers...both handled and just the bits:
    Attached Thumbnails Attached Thumbnails Hollowing Cutter Setup 03 - 800.jpg   Hollowing Cutter Setup 05 - 800.jpg
    Nov 2008
    Ireland
    28
    Hi John,
    I have the Sorby tear-drop scraper and I sharpen it the way Vaughn does on a platform and just turn it with my fingers (gloves on). I sharpen my scraper at 80 degrees and it works fine. The only advice I would offer is to grind lightly and keep the piece moving so that you don't end up with a flat spot.
    Lake City, Florida
    498
    Quote Originally Posted by Brendan McAreavy View Post
    I second that!! Very lightly and keep it moving -- it doesn't take much.
    Tony
    Tony, BCE '75
    Goodland, Kansas
    4,834
    Ditto. 80 degrees and keep it moving.
    Bernie W.
    Drums, PA
    292
    I use a tear drop scraper.
    I lay it flat on a good diamond hone. It hasn't seen a grinding wheel in years.
  1. Difference Between a Bowl Scraper and a Shear Scraper
    Last Post: 06-19-2012, 05:02 AM
  2. 20% off Sorby tools
    By John French in forum Hot Deals
    Last Post: 05-18-2012, 02:55 AM
  3. 3 tear table
    Last Post: 03-05-2011, 03:25 AM
  4. Tear Drop Cutting Tips for Hollowing Bar
    Last Post: 12-03-2010, 03:00 AM
  5. Have you shed a tear lately ?
    Last Post: 06-08-2010, 03:57 PM
